SMB switch and trunking
kmigmar805
Hello Experts,
Could anyone confirm if the following model support VLAN trunking? We are planning to replace a Dell PowerConnect 2724 switch which cannot properly talk to our Catalyst 3750-X. We have discovered that Dell switch requires GVRP enabled to send VLAN trunking to Cisco switches.
Due to budget constraints we are looking into buying a small business cheaper Cisco switch such as this one:
Catalyst 3560CG-8PC-S
http://www.cisco.com/en/US/products/ps11290/prod_models_comparison.html#3560
Thank you so much!
Yes, this switch will play nicely with your 3750-X inclusive trunking (and other stuff):
http://www.cisco.com/en/US/prod/collateral/switches/ps11527/ps11289/data_sheet_c78-639705_ps11290_Products_Data_Sheet.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
dsolangon
Gvrp is equivalent to vtp in Cisco. And 3750x is definitely supporting trunking but for inter vlan u need to have the iOS license
If you don't need the layer3 function and for layer 2 function only use2960
