SMX-ES3-16-P
andrewbishop18
Can anyone tell me which (if any) routers in the 4000 series the SMX-ES3-16-P card is compatible with?
Thanks in advance.
Reza Sharifi
Its compatible with several models.
see link;
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#ethernet-switch
Reza Sharifi
see link;
Thanks for your help,
whilst i have your attention, can you tell me which is the NIM equivalent of the
EHWIC-4ESG ?
As i understand this is a layer 3 card but i can only find layer 2 NIM equivalents.
Thanks.
I think, NIM-ES2-4 is the equivalent to EHWIC-4ESG.
According to the data sheet it is layer-2 only.
Have a look at the data sheet:
The 4- and 8-port Gigabit Ethernet LAN Switch NIMs provide line-rate Layer 2 switching across onboard Gigabit Ethernet ports. The 4-port NIM has four 10/100/1000 switched Gigabit Ethernet ports. The 8-port NIM has eight 10/100/1000 switched Gigabit Ethernet ports, with a PoE/PoE+ version capable of powering all eight ports. The NIMs furthermore enable direct module-to-module communication through the use of the multigigabit fabric (MGF).
Link:
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data_sheet_c78-612808.html
