04-10-2018 05:13 PM - edited 03-08-2019 02:36 PM
I'm seeing a few logging in the Cisco 3850 switch which intermittently will cause a high latency or request time out.
-Traceback= 1#070eb7d9ba6f0bc87b2562bfd825b241 c:30F1D000+82AF8
Apr 10 03:30:02.799: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:30:03.175: %SYS-3-CPUHOG: Task is running for (2350)msecs, more than (2000)msecs (0/0),process = SNMP ENGINE.
-Traceback= 1#070eb7d9ba6f0bc87b2562bfd825b241 ld:2B306000+13F94
Apr 10 03:34:59.876: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:35:00.267: %SYS-3-CPUHOG: Task is running for (2330)msecs, more than (2000)msecs (2/2),process = SNMP ENGINE.
-Traceback= 1#070eb7d9ba6f0bc87b2562bfd825b241 :54BAE000+4793808 :54BAE000+16E2548 :54BAE000+16E3148 :54BAE000+16DFF78 :54BAE000+44169E0 :54BAE000+4416D30 :54BAE000+44148F4 :54BAE000+43DCB54 :54BAE000+43C97FC :54BAE000+43FEEAC :54BAE000+4763FFC
Apr 10 03:35:02.887: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:35:03.266: %SYS-3-CPUHOG: Task is running for (2330)msecs, more than (2000)msecs (0/0),process = SNMP ENGINE.
-Traceback= 1#070eb7d9ba6f0bc87b2562bfd825b241 tdlcmicompatlib:30D42000+A9F8 tdlcmicompatlib:30D42000+20D94 snmp:3027B000+35678 snmp:3027B000+15628 snmp:3027B000+15960 :54BAE000+16E0044 :54BAE000+44169E0 :54BAE000+4416D30 :54BAE000+44148F4 :54BAE000+43DCB54 :54BAE000+43C97FC
Apr 10 03:40:00.354: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:45:01.837: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:45:04.236: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:45:04.611: %SYS-3-CPUHOG: Task is running for (2070)msecs, more than (2000)msecs (7/7),process = SNMP ENGINE.
-Traceback= 1#070eb7d9ba6f0bc87b2562bfd825b241 snmp_db:318A1000+2A934 :54BAE000+16E4508 :54BAE000+16E00C4 :54BAE000+44169E0 :54BAE000+4416D30 :54BAE000+44148F4 :54BAE000+43DCB54 :54BAE000+43C97FC :54BAE000+43FEEAC :54BAE000+4763FFC
Apr 10 03:50:01.815: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:50:04.812: %SNMP-3-CPUHOG: Processing GetBulk of cldcClientWgbStatus
Apr 10 03:55:02.962: %SNMP-3-CPUHOG: Processing GetBulk of bsnMobileStationCcxVersion
I found a bug which very similar CSCuy15293
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy15293/?rfs=iqvred
but it didn't mentioned which upgrade version to fixed this issue, may i know what is the workaround on this bug?
Gilbert
04-10-2018 07:55 PM - edited 04-10-2018 07:56 PM
Raise a TAC Case. As of 30 March 2018, there are 110 Support Cases associated with this bug.
There are two workarounds:
1. Configure an SNMP filter; and/or
2. Upgrade the firmware.
04-30-2018 05:57 AM
You mention that one of the solutions is upgrading the firmware, but which version?
CSCuy15293 says 'No release planned to fix this bug'
04-30-2018 01:30 PM
