02-21-2018 06:59 AM - edited 03-08-2019 01:58 PM
I am trying to create a SNMP ACL on a Nexus 9K. Previously I have created them using command similar to:
snmp-server community MyCommunityString RO 1
However, from what I can gather on the new commands, I have the following created to try to create the equivalent of the above:
ip access-list MyACL
10 permit udp 10.1.1.1/32 eq snmp any
snmp-server community PSCUMARS group network-operator
snmp-server community MyCommunityString use-acl MyACL
However, this is not working when we scan but will work if I remove the ACL.
Any ideas?
Solved! Go to Solution.
02-21-2018 08:43 AM
02-21-2018 08:43 AM
02-21-2018 10:50 AM
That seems to have resolved it, thanks!
