SNMP ENGINE causing high CPU
lmanavalan
Level 3
Level 3
The average CPU utilization is 60% and at times hits 95% on Cisco 7206VXR (NPE-G1) with System image file is "disk2:c7200-adventerprisek9-mz.124-24.T5.bin":
When i checked the router SNMP ENGINE is causing the high utilization (60%).
When i stopped the monitoring from solar wind then the CUP is back to 6%.
i am not facing this issue on another similar router but that's running System image file is "disk2:c7200-advipservicesk9-mz.152-4.M5.bin"
Is this a bug or very old version of code causing the issue.
regards
Logesh
steven.t27
I believe I am having this issue as well on my 6509. Did you get this resolved?
one server was performing avtomatic daily snmp-walk on our 6509 also causing high cpu usage. Solution was toconfigure snmp-view excluding all unnecesary MIBs.
I think I used this blog as a reference when configuring snmp-view:
http://packetlife.net/blog/2010/dec/20/configuring-snmp-views-deter-runaway-nms-polling/
Steven,
Please send me the following :
show proc cpu sort | inc CPU|PID|SNMP ENG
show stacks <SNMP ENG>
looking forward to your reply,
Claudio Gonzalez
lmanavalan
Level 3
Level 3
Didn't has time to troubleshoot the SNMP 😞 so, i end up upgrading the IOS of this router (c7200-adventerprisek9-mz.124-24.T5.bin) similar to the other router (c7200-advipservicesk9-mz.152-4.M5.bin) and the problem disappeared.
regards
Logesh
