SNMP - MIB
ney25
Level 2
Level 2
Hi NetPro.
would it be possible if i wanna configure the switch to send alert / alarm while the CPU Utilization hit to 50% - 80% to my monitoring server ?
i have check with the monitoring administrator , he was mentioned must give him " MIB " . thus i am wondering where and how can i get this mib file for him ?
appreciate your reply . thanks netpro.
jack
Lucien Avramov
Level 10
Level 10
You can use RMON for this;
http://www.cisco.com/en/US/tech/tk961/technologies_configuration_example09186a0080094478.shtml
Something for cpmCPUTotalMonIntervalValue (OID
1.3.6.1.4.1.9.9.109.1.1.1.1.10) is probably what you want...
rmon event # log trap
description
owner
rmon alarm # .1.3.6.1.4.1.9.9.109.1.1.1.1.10.x absolute
rising-threshold xxxx falling-threshold xxxx owner
cpmCPUTotalMonIntervalValue OBJECT-TYPE
SYNTAX Gauge32 (0..100)
UNITS "percent"
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The overall CPU busy percentage in the last
cpmCPUMonInterval period.
This object deprecates the object cpmCPUTotal5secRev."
::= { cpmCPUTotalEntry 10 }
Hi Lavramov.
Good Day, would you mind to guide me the easiest way ? as i have tried out but don't seems to be work.
Switch Portion :
i want to monitor the CPU utilization if CPU hit to 30% - 50%. then it will trigger the alarm and send to Netview.
so, what should i configure into the Switch ? currently i have configured this to my switch but dont think it's work.
rmon event 1 log trap public description " CPU Util Above 30% " owner config
rmon event 2 log trap public description " CPU Util Below 50% " owner config
rmon alarm 1 lsystem.56.0 60 absolute rising-threshold 50 1 falling-threshold 30 2 owner config
rmon alarm 2 lsystem.8.0 60 absolute rising-threshold 480000000 falling-threshold 400000000 3 owner config
Your reply will be highly appreciated.
