SNMP - modify IF Bandwitch
JeroenGeldhof
The ifspeed OID 1.3.6.1.2.1.2.2.1.5 in RFC1213 is read-only.  Is there any other OID/MIB that allows to configure the Bandwitch through SNMP?
Best regards,
Jeroen
Collin Clark
What do you mean? Set the physical port to 10, 100 or 1000mbps? Set the bandwidth statement under the interface?
Hi Collin,
indeed we mean the port setting.  1Gbps, 10Gbps, 10Mbps, 100Mbps.
Best regards,
Jeroen
