%C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 4880 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/1 in vlan 207
Dear All,
i have one C4500 as a core switch connected to access switch 3750X (6 switches as stack) so we have received this log on C4500:
001201: Apr 23 20:35:36.121: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 2395 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/1 in vlan 207
001202: Apr 24 03:17:16.226: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 8460 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/1 in vlan 207.
when this message happened one of application is hanging "apatchi server"?
can anyone help to troubleshoot and olve this issue?
8 Replies 8
check the NIC of the Apache server, it could be faulty. You can configure the C4500 to drop packets with a source of 00:00:00:00:00:00"
C4500#conf t
C4500(config)#vlan 207
C4500(config-vlan-207)#static-mac-address 00:00:00:00:00:00 drop.
Hi Georg,
tha apache server connected to C4500 and the invalid mac address coming from the uplink to access switch. is there any way to trace this mac address?
thanks
Hello Mohammed,
your best option is probably to use Wireshark to trace the MAC address...
Hi Georg,
thanks for your reply.
do you want me to use the source is vlan 207 or ten1/1?
do you thing this issue from this invalid mac address?
source should be Vlan 207...
Unless you have some sort of multicasting configured on your network, the all zero MAC address is most likely invalid...
we are not enable any multicast, but the issue happened once we receive this log.
Hi. Do you have IP Device Tracking enabled on your 3750-x stack?
Andy
Hi All,
No i dont have IP device tracking, but during the issue happened i have receive attached error in apache server. Is it related to network issue ?
