SNMP RW - PS reset
saquib.tandel
Hello All
we need to reset the password for a remote cisco router, no support available on the site.
the SNMP read and read-write is still there on the device, is it possible to reset the password with SNMP RW string
appreciate some quick feedback
thanks
ST
Reza Sharifi
As far as I know, you can't change the password with SNMP.  If you have remote access to the device you can change it via cli.
