SG500X
Can i user all the uplink and the stacking ports when i convert the switch from stacking mode to standalone switch ? , that mean i will have 4 SFP+ ports all of them working as uplink
2 Accepted Solutions
Hitesh Vinzoda
Level 10
Level 10
Dude,
If you use the switch is standalone mode all the ports are available as standard ports and can be used as an uplink
Non-Stacking standalone option: • Ports XG3/S1 and XG4/S2 available as standard network ports – Speed—1G or 10G • Port S1, S2 and 5G are not available • Ports XG1 and XG2 are available as standard network ports – Speed—1G or 10G
Hitesh
pls rate useful posts.
These are the uplink options for Cisco 500 series#
Stacking Option One (default option):
• Ports XG3/S1 and XG4/S2 are configured as stack ports
– Speed—1G, 10G, 1G/10G-auto
 5G is not available
– Speed—1G or 10G
Stacking Option Two:
• Ports XG3/S1 and XG4/S2 are not available
• Port S1, S2 and 5G are configured as stack ports
– Speed—1G, 5G, 1G/5G-auto
– Speed—1G or 10G
– Speed—1G or 10G
– Speed—1G or 10G
- HTH
Hitesh Vinzoda
Level 10
Level 10
Dude,
Hitesh
Thanks alot but,
what if i will use the switch with the stack ports what options can i get ?
 5G is not available
– Speed—1G or 10G
– Speed—1G or 10G
– Speed—1G or 10G
– Speed—1G or 10G
- HTH
Thanks alot for your support
