Solarwinds issues?
John Blakley
This may seem a little off-topic, but I'm using Solarwinds to map ports on my 3750 and I'm getting discrepancies. Solarwinds will say something is connected and give me a MAC address, but then I look at the switch using sh mac-address-table inter (whatever), and it says that NOTHING is connected.
I'm leaning toward trusting the switch more, but not sure. Oh, and it's not as simple as tracing the cable. I have a LOT of these ports with solarwinds saying there's something there and Cisco saying there's not, and vice-versa. Does anyone use anything else to map these ports that seem to be more reliable?
Thanks!
John
HTH, John *** Please rate all useful posts ***
singhsaju
Level 4
Level 4
Hi John,
You can try software from following site.I used it to map ports . You can use it for 15 days as free trial.
http://www.netscantools.com
Saju
Pls rate helpful posts
packettrapper
shamless self promotion: you should try PacketTrap Switch Port Mapper. Will solve the problem. www.PacketTrap.com
