[Solved] Catalyst C2960s reboot
Xavier RICOL
We have a stack with 2 C2960S-48TS-L and 1 C2960S-24TS-L. Monday we upgraded the stack with the latest firmware 15.0(2)SE8-UNIVERSALK9.
Since then, 2 switches of the stack reboot twice or more by day. Without any action.
We upgraded another stack, with the same switches, and no reboot since the upgrade:
I find nothing in the events.
Could you please help us ?
Kind regards
Cedric
The switch crashed to due excessive amount of MAC flapping.  This is generally caused when the ports are not configured for EtherChannel.
If your company's most senior network engineer didn't work this out for himself, then you'd better get someone to manage the network properly.
20 Replies 20
Leo Laohoo
Do NOT use CNA.
Remote into the stack and post the complete output to the following commands:
1.  dir flash2:
2.  dir flash3:
Thanx for your answer.
I'm sorry i'm a newbie, my coworker who is certified is on holiday.
Do you mean to plug directly on one of the switch and type the command in hyperterminal, please ?
Cedric
If you want to learn Cisco, then now is the chance.
Yes.  It's not rocket science.  The outputs I'm looking for a "show" commands and are non-disruptive.
I downloaded the USB To Serial Driver, installed it, i plugged the mini usb wire, i launched hyperterminal, i choose the right port (COM5), i changed the values (9600 baud, 8 data bits, no parity, 1 stop bit, and no flow control ). But the connection is refused? Do i need to restart the switch ?
I tried another port (COM1) which is the port on my motherboard, i can connect !! But i can't write anithing (logical).
Cedric
Well, the C2960S-24TS-L reboot once again, but always impossible to connect to console.
if your struggling with console access perhaps you could try and log in via ssh/telnet from another device in the network
Finally i succeeded, i post the results above.
I successed to connect, but i must wait, i have all the events that pass, since january !
Finally i have the results of the 2 commands:
SW_DATAS_01#dir flash2:
Directory of flash2:/
    2  -rwx        5886  Aug 17 2015 13:41:57 +02:00  config.text
    3  -rwx        1916  Aug 17 2015 13:41:57 +02:00  private-config.text
    4  -rwx        5683  Jul 16 2015 14:32:25 +02:00  config.text.backup
    5  drwx         512  Aug 17 2015 12:57:31 +02:00  c2960s-universalk9-mz.122-
55.SE7
   69  -rwx        1916  Jul 16 2015 14:32:25 +02:00  private-config.text.backup
   70  -rwx        3096   Jan 2 2006 01:02:43 +01:00  multiple-fs
   71  drwx         512  Aug 17 2015 13:10:52 +02:00  c2960s-universalk9-mz.150-
2.SE8
  686  drwx        2560   Jan 2 2006 06:25:26 +01:00  crashinfo_ext
  718  drwx        2560   Jan 2 2006 01:00:02 +01:00  crashinfo
57931776 bytes total (27382272 bytes free)
SW_DATAS_01#
SW_DATAS_01#dir flash3:
Directory of flash3:/
    5  drwx         512  Aug 17 2015 13:10:52 +02:00  c2960s-universalk9-mz.150-
2.SE8
  620  -rwx        1916  Jul 16 2015 14:32:25 +02:00  private-config.text.backup
  622  -rwx        3096   Jan 2 2006 01:02:43 +01:00  multiple-fs
57931776 bytes total (38411776 bytes free)
SW_DATAS_01#
Ok, the contents of these two sub-directories are what I'm interested in.
Post the complete output to the following commands:
1.  dir flash2:crashinfo;
2.  dir flash2:crashinfo_ext
I also would like to know if the stack's time and date settings are automatically configured for NTP or not, so I'd like to see the output to the command "sh clock".
OK:
SW_DATAS_01#dir flash2:crashinfo
Directory of flash:/crashinfo/
  722  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_1
  723  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_2
  724  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_3
  725  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_4
  726  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_5
  727  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_6
  728  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_7
  729  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_8
  730  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_9
  731  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_10
  732  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_11
  733  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_12
  734  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_13
  735  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_14
  736  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_15
  737  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_16
  738  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_17
  739  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_18
  740  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_19
  741  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_20
  742  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_21
  743  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_22
  744  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_23
  745  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_24
  746  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_25
  747  -rwx        1403   Jan 2 2006 01:00:02 +01:00  crashinfo_26
  748  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_27
  749  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_28
  750  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_29
  751  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_30
  752  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_31
  753  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_32
  754  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_33
  755  -rwx        1448   Jan 2 2006 01:00:02 +01:00  crashinfo_34
57931776 bytes total (26366464 bytes free)
SW_DATAS_01#
Directory of flash:/crashinfo_ext/
  687  -rwx      332329   Jan 2 2006 06:25:26 +01:00  crashinfo_ext_1
  688  -rwx      336124   Jan 2 2006 10:20:55 +01:00  crashinfo_ext_2
  689  -rwx      339999   Jan 2 2006 11:40:02 +01:00  crashinfo_ext_3
  690  -rwx      335019   Jan 2 2006 14:11:06 +01:00  crashinfo_ext_4
  691  -rwx      319895   Jan 2 2006 18:36:23 +01:00  crashinfo_ext_5
  692  -rwx      332005   Jan 2 2006 23:03:11 +01:00  crashinfo_ext_6
  693  -rwx      325194   Jan 3 2006 02:36:19 +01:00  crashinfo_ext_7
  694  -rwx      341838   Jan 3 2006 06:24:23 +01:00  crashinfo_ext_8
  695  -rwx      332264   Jan 3 2006 10:15:53 +01:00  crashinfo_ext_9
  696  -rwx      328774   Jan 3 2006 11:39:27 +01:00  crashinfo_ext_10
  697  -rwx      323528   Jan 3 2006 14:52:05 +01:00  crashinfo_ext_11
  698  -rwx      350877   Jan 3 2006 16:28:41 +01:00  crashinfo_ext_12
  699  -rwx      328691   Jan 3 2006 21:00:08 +01:00  crashinfo_ext_13
  700  -rwx      325711   Jan 4 2006 02:26:35 +01:00  crashinfo_ext_14
  701  -rwx      343188   Jan 4 2006 04:56:25 +01:00  crashinfo_ext_15
  702  -rwx      337928   Jan 4 2006 10:24:53 +01:00  crashinfo_ext_16
  703  -rwx      340325   Jan 4 2006 11:48:18 +01:00  crashinfo_ext_17
  704  -rwx      314997   Jan 4 2006 14:01:54 +01:00  crashinfo_ext_18
  705  -rwx      333465   Jan 4 2006 16:08:46 +01:00  crashinfo_ext_19
  706  -rwx      342140   Jan 4 2006 20:58:22 +01:00  crashinfo_ext_20
  707  -rwx      342101   Jan 4 2006 23:12:55 +01:00  crashinfo_ext_21
  708  -rwx      328741   Jan 5 2006 05:13:47 +01:00  crashinfo_ext_22
  709  -rwx      334087   Jan 5 2006 06:59:45 +01:00  crashinfo_ext_23
  710  -rwx      331829   Jan 5 2006 11:12:43 +01:00  crashinfo_ext_24
  711  -rwx      348358   Jan 5 2006 14:33:49 +01:00  crashinfo_ext_25
  712  -rwx      240574   Jan 5 2006 18:54:57 +01:00  crashinfo_ext_26
  713  -rwx      310949   Jan 5 2006 20:26:13 +01:00  crashinfo_ext_27
  714  -rwx      308440   Jan 5 2006 23:30:02 +01:00  crashinfo_ext_28
  715  -rwx      310202   Jan 6 2006 02:18:27 +01:00  crashinfo_ext_29
  716  -rwx      307331   Jan 6 2006 06:11:51 +01:00  crashinfo_ext_30
  717  -rwx      349210   Jan 6 2006 10:07:03 +01:00  crashinfo_ext_31
  718  -rwx      330039   Jan 6 2006 11:17:33 +01:00  crashinfo_ext_32
  719  -rwx      349547   Jan 6 2006 14:34:13 +01:00  crashinfo_ext_33
  720  -rwx      320474   Jan 6 2006 19:39:19 +01:00  crashinfo_ext_34
SW_DATAS_01#
It seems completely out of clock:
SW_DATAS_01#sh clock
*21:54:29.180 CET Fri Jan 6 2006
SW_DATAS_01#
Ok, can you attach the three files into this thread?  I want to see them.
Could you please help me a little to do it?
I have a ftp server, with administrateur as username.
I tried to use the command ip ftp username to add the username, but invalid input detected.
Use TFTP instead.
Command:  copy flash:/crashinfo_ext/crashinfo_ext_32 tftp://<TFTP IP address>/crashinfo_ext_32
