06-08-2015 01:31 AM - edited 03-08-2019 12:26 AM
EDIT:
Hello guys,
what a stupid mistake from me! I've forgot that i have applied some basic security configuration, which included command to drop all IP packets with Options field set:
ip options drop
Because IGMP Membership Report packets use Router Alert Option this type of traffic was dropped unconditionally.
Hello Everybody,
our Cisco 6509-E System Version:DUAL-Sup720-12.2(33)SXJ6
is not processing IGMP Membership Reports on SVIs, for this example I've configured SVI VLAN 920 as LAN SVI and SVI VLAN 608 serves as PIM uplink. The switch is in default configuration.
ip multicast-routing ! interface Vlan920 description tvcore-iptv-test ip address 172.16.40.1 255.255.255.0 ip helper-address 172.16.8.11 ip pim sparse-mode
when clients try to Join (Report) some groups nothing happens regarding the mroute and IGMP Group table :
#show ip igmp groups IGMP Connected Group Membership Group Address Interface Uptime Expires Last Reporter Group Accounted 224.0.1.40 Vlan608 4d04h 00:02:36 109.74.150.53
#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 4d16h/00:02:58, RP 109.74.150.19, flags: SJPL
Incoming interface: Vlan608, RPF nbr 109.74.150.54
Outgoing interface list: Null
Output from debug ip igmp shows for VLAN 920 just :
Jun 8 08:07:15.405: IGMP(0): Send v2 general Query on Vlan920 Jun 8 08:08:15.406: IGMP(0): Send v2 general Query on Vlan920 Jun 8 08:09:15.407: IGMP(0): Send v2 general Query on Vlan920 Jun 8 08:10:15.408: IGMP(0): Send v2 general Query on Vlan920
Output from some diagnostic commands:
#show version Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISE_WAN-M), Version 12.2(33)SXJ6, RELEASE SOFTWARE (fc3) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2013 by Cisco Systems, Inc. Compiled Fri 19-Jul-13 03:29 by prod_rel_team ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1) shc3-tv-core-RB9 uptime is 4 days, 16 hours, 49 minutes Uptime for this control processor is 4 days, 16 hours, 48 minutes Time since shc3-tv-core-RB9 switched to active is 4 days, 16 hours, 47 minutes System returned to ROM by reload at 17:26:46 CDT Wed Jun 3 2015 (SP by reload) System restarted at 17:30:09 CDT Wed Jun 3 2015 System image file is "disk0:s72033-adventerprise_wan-mz.122-33.SXJ6.bin" Last reload reason: Reload Command cisco WS-C6506 (R7000) processor (revision 3.0) with 983008K/65536K bytes of memory. Processor board ID TBA05192265 SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache Last reset from power-on 66 Virtual Ethernet interfaces 52 Gigabit Ethernet interfaces 8 Ten Gigabit Ethernet interfaces 1917K bytes of non-volatile configuration memory. 8192K bytes of packet buffer memory. 65536K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102
#show module Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL11445EGK 3 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAD0928040J 4 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1027UDT3 5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL1251D9NB 6 2 Supervisor Engine 720 (Hot) WS-SUP720-3BXL SAD100405CS Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ------ ------------ ------------ ------- 1 001e.13f5.8d00 to 001e.13f5.8d2f 2.6 12.2(14r)S5 12.2(33)SXJ6 Ok 3 0014.1c6b.d694 to 0014.1c6b.d697 2.2 12.2(14r)S5 12.2(33)SXJ6 Ok 4 0018.199d.4430 to 0018.199d.4433 2.4 12.2(14r)S5 12.2(33)SXJ6 Ok 5 001e.be6e.ad74 to 001e.be6e.ad77 5.7 8.5(2) 12.2(33)SXJ6 Ok 6 0011.9202.559c to 0011.9202.559f 4.5 8.4(2) 12.2(33)SXJ6 Ok Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 1 Centralized Forwarding Card WS-F6700-CFC SAD093401RZ 2.0 Ok 3 Distributed Forwarding Card WS-F6700-DFC3BXL SAL1127TRTK 5.3 Ok 4 Centralized Forwarding Card WS-F6700-CFC SAL1027TQ4A 2.0 Ok 5 Policy Feature Card 3 WS-F6K-PFC3BXL SAD1135Y334 1.9 Ok 5 MSFC3 Daughterboard WS-SUP720 SAD1135Y333 2.2 Ok 6 Policy Feature Card 3 WS-F6K-PFC3BXL SAD100309G8 1.8 Ok 6 MSFC3 Daughterboard WS-SUP720 SAL1017L90L 2.5 Ok Mod Online Diag Status ---- ------------------- 1 Pass 3 Pass 4 Pass 5 Pass 6 Pass
#show ip igmp interface vlan 920 Vlan920 is up, line protocol is up Internet address is 172.16.40.1/24 IGMP is enabled on interface Current IGMP host version is 2 Current IGMP router version is 2 IGMP query interval is 60 seconds IGMP configured query interval is 60 seconds IGMP querier timeout is 120 seconds IGMP configured querier timeout is 120 seconds IGMP max query response time is 10 seconds Last member query count is 2 Last member query response interval is 1000 ms Inbound IGMP access group is not set IGMP activity: 0 joins, 0 leaves Multicast routing is enabled on interface Multicast TTL threshold is 0 Multicast designated router (DR) is 172.16.40.1 (this system) IGMP querying router is 172.16.40.1 (this system) No multicast groups joined by this system IGMP snooping is globally enabled IGMP snooping CGMP-AutoDetect is globally enabled IGMP snooping is enabled on this interface IGMP snooping fast-leave (for v2) is disabled IGMP snooping querier is disabled. IGMP snooping explicit-tracking is enabled IGMP snooping last member query response interval is 1000 ms IGMP snooping report-suppression is enabled IGMP snooping query interval is 60000 ms IGMP configured snooping query interval is 60000 ms IGMP snooping querier version is 3 IGMP snooping querier - TCN query count is 2 IGMP snooping querier - TCN query interval is 10000 ms
Any help or hint would be appreciated ;-)
Thanks in advance
Vincent Vlk
06-08-2015 05:53 AM
What does "show ip mroute 224.0.1.40 count" say? Maybe the source IP address of group 224.0.1.40 is unreachable from the router (that is, the group fails the RPF check)...
06-08-2015 06:32 AM
Hi Iulian,
224.0.1.40 is AUTO-RP-DISCOVERY group automatically added by router. I'am trying to join some other private groups, like our 239.1.152.X range or from our GLOP range 233.X.Y.Z. That is the problem, that i don't see this group addresses in mroute or IGMP table, with debug output showing only General Query on VLAN 920, but not any Membership report.
#show ip mroute 224.0.1.40 count IP Multicast Statistics 1 routes using 552 bytes of memory 1 groups, 0.00 average sources per group Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc) Group: 224.0.1.40, Source count: 0, Packets forwarded: 0, Packets received: 0
But thanks anyway for your input.
