Some clients can't communicate with secondary IP subnet
eric nguyen
I have an issue that's been bugging me since this morning. This site has a single VLAN, 1, and the gateway is an SVI for VLAN 1 with a secondary IP of 192.168.116.254/24 and a primary IP of 10.53.16.1/22.
Some clients on the 10 network can ping servers on the 192 network, but some cannot. From the switches, I can ping the servers at 192.168.116.64 and .80. The servers and most of the clients are connected to the same switch stack, but still can't talk. I have attached a diagram and the interface configs are below. There are no ACLs on any of the switches either.
4500X
interface Vlan1
 description GATEWAY FOR LAN
 ip address 192.168.116.254 255.255.255.0 secondary
 ip address 10.53.16.1 255.255.252.0
interface TenGigabitEthernet1/1/3
 switchport mode trunk
 channel-group 1 mode active
interface TenGigabitEthernet2/1/3
interface Port-channel1
 switchport
3850 Stack
interface Vlan1
 ip address 10.53.16.5 255.255.252.0
interface GigabitEthernet1/1/1
interface GigabitEthernet4/1/1
5 Replies 5
Julio Carvajal
Can you try to do a ping from one PC to a server that does not work and check if with wireshark you see the packets reaching the server?
Have you make sure all of the PCs have the right Default gateway on their corresponding VLAN?
Do you see the ARP mapping on their network table?
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
I have not done a packet capture yet.
Yes, the PCs have the correct default gateway, they all point to the 4500s.
Yes, both the client and servers are in the ARP tables of the 4500s.
Regarding the PCs that do not reach the servers, can they ping the other VLAN1 ip address, i.e. the one other than their gateway address?
Parvesh Paliwal
Level 3
Level 3
Can you share a traceroute for different subnets from the clients subnet(s) ?
Two things in the partial config shown puzzle me though I am not sure if either is really the problem.
- the original post says there is only a single vlan. but the connection between switches is configured as a trunk? why is there a trunk if there is only a single vlan?
- the 4500 has the primary and secondary addresses but the 3850 has only the primary address. I wonder what would happen if the secondary address were configured on the 3850 also?
Rick
Rick
