06-04-2017 04:28 AM - edited 03-08-2019 10:50 AM
some POE Ports in Cisco 4500 Switch are not operating. But non POE Devices works Properly on those POE ports.
only some specific ports on module are not working properly for POE. can someone tell me what could be the issue
Hahsim
06-04-2017 01:52 PM
Post the complete output to the following commands:
06-05-2017 10:00 AM
this is the output, hence problem is in module 2
EDGE-9.1# sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 07-Apr-15 10:32 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12E3D2C8
ROM: 12.2(44r)SG5
Darkside Revision 4, Nexu Revision 9, Fortooine Revision 1.32
EDGE-9.1 uptime is 34 weeks, 6 days, 22 hours, 11 minutes
System returned to ROM by reload
System image file is "bootflash:cat4500e-ipbasek9-mz.150-2.SG10.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4506-E (MPC8548) processor (revision 8) with 524288K bytes of memory.
Processor board ID FOX1529GFJ2
MPC8548 CPU at 1GHz, Supervisor 6L-E
Last reset from Reload
2 Virtual Ethernet interfaces
148 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
EDGE-9.1#sh power inline module 2
Available:1400(w) Used:821(w) Remaining:579(w)
Interface Admin Oper Power(Watts) Device Class
From PS To Device
Gi2/1 auto off 0.0 0.0 n/a n/a
Gi2/2 auto on 12.9 12.0 IP Phone 7945 3
Gi2/3 auto off 0.0 0.0 n/a n/a
Gi2/4 auto on 12.9 12.0 IP Phone 7975 3
Gi2/5 auto off 0.0 0.0 n/a n/a
Gi2/6 auto off 0.0 0.0 n/a n/a
Gi2/7 auto on 12.9 12.0 Ieee PD 3
Gi2/8 auto on 12.9 12.0 IP Phone 7945 3
Gi2/9 auto off 0.0 0.0 n/a n/a
Gi2/10 auto off 0.0 0.0 n/a n/a
Gi2/11 auto on 12.9 12.0 IP Phone 7945 3
Gi2/12 auto off 0.0 0.0 n/a n/a
Gi2/13 auto on 12.9 12.0 Ieee PD 3
Gi2/14 auto on 6.8 6.3 IP Phone 7942 2
Gi2/15 auto off 0.0 0.0 n/a n/a
Gi2/16 auto off 0.0 0.0 n/a n/a
Gi2/17 auto off 0.0 0.0 n/a n/a
Gi2/18 auto off 0.0 0.0 n/a n/a
Gi2/19 auto on 12.9 12.0 Ieee PD 3
Gi2/20 auto on 6.8 6.3 IP Phone 7942 2
Gi2/21 auto off 0.0 0.0 n/a n/a
Gi2/22 auto off 0.0 0.0 n/a n/a
Gi2/23 auto on 12.9 12.0 Ieee PD 3
Gi2/24 auto on 6.8 6.3 Cisco/Ieee PD 2
Gi2/25 auto on 6.8 6.3 Cisco/Ieee PD 2
Gi2/26 auto off 0.0 0.0 n/a n/a
Gi2/27 auto on 12.9 12.0 IP Phone 7945 3
Gi2/28 auto off 0.0 0.0 n/a n/a
Gi2/29 auto on 12.9 12.0 IP Phone 7945 3
Gi2/30 auto on 12.9 12.0 IP Phone 7945 3
Gi2/31 auto on 12.9 12.0 IP Phone 7945 3
Gi2/32 auto off 0.0 0.0 n/a n/a
Gi2/33 auto off 0.0 0.0 n/a n/a
Gi2/34 auto on 5.4 5.0 IP Phone 7906 2
Gi2/35 auto off 0.0 0.0 n/a n/a
Gi2/36 auto on 12.9 12.0 IP Phone 7945 3
Gi2/37 auto on 12.9 12.0 IP Phone 7945 3
Gi2/38 auto off 0.0 0.0 n/a n/a
Gi2/39 auto off 0.0 0.0 n/a n/a
Gi2/40 auto on 18.1 16.8 AIR-CAP2702I-E-K9 4
Gi2/41 auto off 0.0 0.0 n/a n/a
Gi2/42 auto on 7.0 6.5 IP Phone 8841 2
Gi2/43 auto on 12.9 12.0 Ieee PD 3
Gi2/44 auto on 7.0 6.5 IP Phone 8841 2
Gi2/45 auto off 0.0 0.0 n/a n/a
Gi2/46 auto on 15.2 14.2 Ieee PD 4
Gi2/47 auto off 0.0 0.0 n/a n/a
Gi2/48 auto off 0.0 0.0 n/a n/a
Totals: 24 on 273.4 254.3
06-05-2017 02:01 PM
Thanks for the output.
Now which port(s) are not powering up the devices?
Can you post the output to the following commands:
06-06-2017 08:56 AM
Thanks Leo for your Reply
* this happened with 6 ports of 48 port module on 4506-E
today i tried to reset the module by putting the below command
hw module 2 reset
it worked and solved the problem, but i am still worry, that i did not find any reason and can it happen again ?
can you explain that why did it happen ? is it a BUG or i need to upgrade the IOS or it is because Module is Faulty ?
i did not find any power consumption issue
i did not find any faulty IP Phone
CDP was enabled
nothing was configured on ports regarding power
I am eagerly waiting your Expert view on this matter
I just want to know the ROOT Cause Analysis of the issue
06-06-2017 03:16 PM
06-06-2017 09:06 PM
Hi Leo
after reset the module, all ports are working. now everything is fine.
but I still did not find any reason for this issue, why this happened ?
should I upgrade the IOS or change the Module ? as it can be happen again in future ?
Hashim
06-06-2017 09:53 PM
I can't tell what is happening because the line card was reset.
02-21-2019 12:09 AM
Hi ,
have the same problem, would you be able to look at the logs and tell us what is the reason, we may still replace the hardware but wanted to confirm if thats required
02-21-2019 12:36 AM
post the logs (if you still have them) and the output of 'sh ver'. Did reseating the module solve your issue (at least temporarily) ?
02-21-2019 12:48 AM
sensitive info erased *
we did not tried to reset the module as we wanted to troubleshoot the issue first
do we need to connect anything to the ports while these are UP UP and then export sh int >
SW2#sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT210*
2 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT210 *
3 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT210 *
4 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT210 *
5 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E CAT21 *
6 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E CAT21 *
M MAC addresses Hw Fw Sw Status
1 *e27f 1.1 Ok
2 *67d7 1.1 Ok
3 *6717 1.1 Ok
4 *e18f 1.1 Ok <- Module 4
5 *0087 1.3 15.1(1r)SG5 03.07.03.E Ok
6 *.008f 1.3 15.1(1r)SG5 03.07.03.E Ok
Mod Redundancy role Operating mode Redundancy status
5 Active Supervisor SSO Active
6 Standby Supervisor SSO Standby hot
W2#sh interfaces gi4/44
GigabitEthernet4/44 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is *e18b)
Description:
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Auto-MDIX on (operational: on)
Last input 2w2d, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
4767828 packets input, 732565275 bytes, 0 no buffer
Received 49461 broadcasts (49445 multicasts)
25028138 packets output, 18354732977 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
SW2#sh interfaces gi4/48
GigabitEthernet4/48 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 2c5a* e18f)
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
7 packets output, 3713 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
02-21-2019 11:15 PM
If I shut the port, the line protocol status goes to disabled. When I re-enable it, it goes to not connect.
If I plug my laptop to the port instead of the PoE device, the port goes up and I have connectivity.
02-22-2019 12:09 AM
I would schedule some downtime and remove/re-insert the entire module. Check if the problem persists after doing that...
02-22-2019 12:10 AM
we will try , is that a known bug , do we need to RMA the module and what warranties we have that even after module restart this issue will not appear after some time
