sonos connected to SG200-50
trih
I have one Cisco SG200-50 switch on my network and a AP 1602i. I have now also connected a Sonos One SL to the network.
At first I had no problem setting up the Sonos and connect to it. Now after one day I am unable to connect to the Sonos with the app. I have tried to turn off the Sonos, restart my phone, turn my phone off and on, deleting all app cache on my phone and reinstalling the app. Nothing works. Can It be network related?
13 Replies 13
I think the Sonos uses multicast, so that has to be set up properly on your WLC.
Make sure your WLC has the settings below: (I found this in a post on the Sonos support site):
- CONTROLLER > GENERAL > AP Multicast Mode = Multicast, group IP is set to 239.1.1.1
- CONTROLLER > MULTICAST > Enable Global Multicast Mode = ON
- CONTROLLER > MULTICAST > Enable IGMP Snooping = ON
- CONTROLLER > mDNS > mDNS Global Snooping = ON
- A single SSID is configured and provides access to the respective VLAN
- mDNS Snooping enabled and default mDNS profile selected under Advanced tab (should not be necessary for Sonos)
- Client isolation is NOT configured.
- WPA2 PSK is used.
I dont have a WLC I only have a single AP
try and set:
station-role workgroup-bridge multicast mode infrastructure
on your autonomous AP.
Also, on the SG200, check if 239.1.1.1 is one of the group addresses learned by IGMP snooping (page 214 of the attached guide)...
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/administration_guide/Cisco_200Sx_v1_4_AG.pdf
Cannot find the find to set station-role workgroup-bridge multicast mode infrastructure on my AP
The sg200 dosen't seems to have learned anything.
can you post the config of your AP ?
Building configuration...
Current configuration : 5479 bytes
! Last configuration change at 12:28:53 UTC Wed Aug 28 2019
! NVRAM config last updated at 12:30:51 UTC Wed Aug 28 2019
version 15.3
no service pad
service password-encryption
hostname XnameX-AP01
logging rate-limit console 9
enable secret 5 $1$1.mY$DS.oE/z/nUFIRufahmCe3.
no aaa new-model
no ip source-route
no ip cef
ip domain name XnameX
ip name-server 172.18.30.12
ip name-server 172.18.30.13
dot11 pause-time 100
dot11 association mac-list 701
dot11 syslog
dot11 vlan-name XnameX-Guest vlan 20
dot11 vlan-name XnameX-LAN vlan 1
dot11 ssid XnameX-Guest
   vlan 20
   authentication open
   mbssid guest-mode
dot11 ssid XnameX-WiFi
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 040D5E242C006E1C503D214E342E285C7973777012677131514556
dot11 network-map
no ipv6 cef
username Cisco password 7 05280F1C2243
username admin password 7 052A080B244E57080954
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 encryption vlan 1 mode ciphers aes-ccm
 ssid XnameX-Guest
 ssid XnameX-WiFi
 antenna gain 0
 stbc
 beamform ofdm
 mbssid
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel 2472
 station-role root
 l2-filter bridge-group-acl
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 input-address-list 701
 bridge-group 1 output-address-list 701
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.14
 no ip route-cache
interface Dot11Radio0.20
 encapsulation dot1Q 20
 no ip route-cache
 bridge-group 20
 bridge-group 20 subscriber-loop-control
 bridge-group 20 spanning-disabled
 bridge-group 20 block-unknown-source
 no bridge-group 20 source-learning
 no bridge-group 20 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid XnameX-Guest
 ssid XnameX-WiFi
 antenna gain 0
 peakdetect
 no dfs band block
 stbc
 beamform ofdm
 mbssid
 channel dfs
 station-role root
interface Dot11Radio1.1
 no ip route-cache
 bridge-group 1
interface Dot11Radio1.20
 no ip route-cache
 bridge-group 20
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.20
 no ip route-cache
 bridge-group 20
interface BVI1
 mac-address 188b.9d40.097a
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip access-list extended SSH-Access
 permit tcp host 172.18.30.50 any eq 22
 permit tcp host 172.18.30.3 any eq 22
access-list 111 permit tcp any any neq telnet
access-list 701 permit 2477.033d.ab1c   0000.0000.0000
access-list 701 permit 001b.77d2.14b5   0000.0000.0000
access-list 701 permit 0811.968e.3c64   0000.0000.0000
access-list 701 permit 7018.8bf7.d221   0000.0000.0000
access-list 701 permit 6067.205d.9854   0000.0000.0000
access-list 701 permit a83e.0e08.4f6a   0000.0000.0000
access-list 701 permit 5848.228e.f4ba   0000.0000.0000
access-list 701 permit 4cd1.a1fc.910b   0000.0000.0000
access-list 701 permit 58d9.c31c.8a5e   0000.0000.0000
access-list 701 permit b070.2d61.7e98   0000.0000.0000
access-list 701 permit d0f8.8ca2.e262   0000.0000.0000
access-list 701 permit 0022.6107.8dc3   0000.0000.0000
access-list 701 permit 38f9.d371.0ad2   0000.0000.0000
access-list 701 permit 48a6.b811.aea0   0000.0000.0000
access-list 701 permit 04f1.280d.d7fe   0000.0000.0000
access-list 701 permit e006.e6ce.9cfd   0000.0000.0000
access-list 701 permit 985f.d34f.4274   0000.0000.0000
access-list 701 permit c033.5e2d.0eb5   0000.0000.0000
access-list 701 permit 3c6a.a734.4d51   0000.0000.0000
access-list 701 deny   0000.0000.0000   ffff.ffff.ffff
bridge 1 route ip
banner motd ^CCUnauthorized access prohibited!^C
line con 0
 access-class 111 in
 login local
line vty 0 4
 access-class SSH-Access in
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
sntp server dc03.XnameX.local
sntp broadcast client
end
you have to disablle p2p blocking. I am not sure what the equivalent setting is on a standalone AP, try:
--> no bridge-group 20 block-unknown-source
If I try to run the following command
AP01(config)#interface dot11Radio 0.1
AP01(config-subif)#no bridge-group 1 block-unknown-source
I get this error
no bridge-group 1 block-unknown-source <cr> not allowed on Dot11Radio0 interface
it's probably not the right command anyway...the problem is that there is almost no information when it comes to standalone APs, but a whole lot when it comes to APs connected to WLCs...
Have a look at the thread below, maybe there is something in there...I'll keep looking as well...
https://en.community.sonos.com/advanced-setups-229000/cisco-wireless-lan-controller-with-sonos-32559
Running
AP01(config)#interface dot11radio 0
AP01(config-if)#antenna gain 0
AP01(config-if)#station-role workgroup-bridge multicast mode infrastructure
returns
Disable Multiple BSSID before configuring this station-role
And I have 2 ssid's on my AP, 1 for LAN og 1 for GUESTS
A little update.
I have connected a little unmanaged HP 1410 switch to my network and then connected the Sonos to it. That gives me the possibility to connect to the speaker with a smartphone. Therefore it is the switch that causes the problem.
Problem with the switch is resolved.
I followed this article https://support.sonos.com/s/article/2118?language=en_US
But there is apparently stil a problem with my AP. I cannot change from ethernet to wifi.
thanks for the updare, very useful article.
The SG200 has a smartport macro for wirless access points, you might want to try and apply that to the port where the AP is connected to...(page 145 of the attached admin guide).
