Source mac not being added with Vlans in packet tracer
dekelley01
I was doing a Lab in packet tracer:
two switches (2960's) and 3 end devices. On sw1 pc1 is connected to int fa0/11 and pc 3 is connected to int fa0/13. Both int belong to vlan 11 & 13
On sw2 PC 2 is connected to fa0/12 also belonging to vlan 11.
In this set up I can ping all devices. However the only mac address being added to the mac table are the def. int macs of each switches port. When I remove all int from vlan 11 & 13 and add them to native vlan 1 mac's are being added to the table.
Am I doing something wrong, or is this a flaw with Packet tracer.
chandra_rc16
Level 4
Level 4
Hi Devin,
PT is fine there is no bug regarding this. You might already know that the MAC-table is refreshed for every 300 sec's, eliminating the records of unused mac's.So i think you probably have checked it after the flush.
Replica of your topolgy:
I replicated your topology and seen that the switches are learning MAC address appropriatley along with their VLANs. I've attached the topolgy.
Here is the VLAN config on switch1:
Here is the VLAN config on switch2:
The ports (Fa0/1)connected the both switches are configured to be trunk.
On switch1: PC0 (Fa0/11) is in vlan11 (10.0.11.1/24) and PC1(Fa0/13) is in vlan13 (10.0.13.1/24).
On switch2: PC2 (Fa0/12) is in vlan11 (10.0.11.2/24). There is no device on Switch2 for vlan13.
As you said, at first both switches will learn the mac's of the ports that are joining them.
Now if i ping PC0(10.0.11.1) from PC2(10.0.11.2), then both the switches are learning the source mac and destination mac.
MAC table of Switch1:
Here it learned the MAC of PC2(000c.8518.9115) and the MAC of PC0(000a.411c.2132).
MAC table of Switch2:
Here it learned the source mac i.e, PC2 (000c.8518.9115) and the destination MAC i.e. PC0(
000a.411c.2132).
After 300 sec's if the devices won't communicate then the MAC of PC0 & PC2 from  both the switches will be eliminated.
Please find attachment for the live topology.
Chandu
Regards, Chandu
Please rate if you find it helpful.
Regards, Chandu
