Sourcing from secondary addresses off single interface
bjdrexler
I have an older cisco firewall  that has multiple secondary address on a single interface.
untagged, L2 connections on all switches off the main interface.
My issue is, I can't seem to route back to the secondary addresses assigned to the port.
devices can only see the primary address.  If, from the firewall box, I  "ping 10.x.x.1 source 10.x.x.10" , this works. Otherwise they fail on a regular ping.
It's seems to only advertise on the primary network. which is a 192.x.x.x.
Is there a set of commands that would force the secondary addresses to advertise in the same fashion as the primary?
Reza Sharifi
That is the correct behavior.  By default the device uses the primary IP address of the out going interface as the source, which is 192.x.x.x.  If you want it to be from 10.x.x.10 address (which is the secondary IP) you need to source it from that IP.
Sam Smiley
Level 3
Level 3
If I get your meaning on this I believe you will find the answer to your question in a previous thread:
https://supportforums.cisco.com/discussion/11738651/multiple-wan-ip-addresses-and-multiple-inside-hosts
This solution will allow you to do port forwarding off of your secondary addresses while having the host answer on that address.
Hope this helps!
Cheers,
Sam
