SP: c6k_power assert failed
Rosa Ladeira
Does anybody have ever heard about :
switches.log.6.gz:Sep  3 14:57:10 singer-outside 83: 5w1d: SP: c6k_power assert failed: '(power_status == POWER_ON || power_status == POWER_FAULTY)' at ../const/native-sp/c6k_power_port_mgmt.c:c6k_pwr_set_ilpower_from_cdp 2655
switches.log.6.gz:Sep  3 14:57:10 singer-outside 84: 5w1d: SP: -Traceback= 40BE78E8 40BF48C8 4125C2D4 413AE694 413AE9A0 409D3BA4 409D3B90
cat6509-wc1#sh version
Cisco IOS Software, s3223_rp Software (s3223_rp-IPBASEK9-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Compiled Fri 22-Oct-10 14:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
cat6509-wc1 uptime is 18 weeks, 1 day, 10 hours, 34 minutes
System returned to ROM by power on (SP by power on)
System restarted at 05:36:18 BRST Mon May 6 2013
System image file is "sup-bootdisk:s3223-ipbasek9-mz.122-33.SXI5.bin"
Last reload reason: Reload Command
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458752K/65536K bytes of memory.
Processor board ID SMG1206N40E
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
3 Virtual Ethernet interfaces
337 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x10
cat6509-wc1#sh power status all
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-6000W       2671.20 63.60  -      -      off
2    WS-CAC-6000W       2671.20 63.60  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      150.36  3.58  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6148A-GE-45AF   112.56  2.68   112.56  2.68  on    on
2    WS-X6148A-GE-45AF   112.56  2.68   112.56  2.68  on    on
3    WS-X6148-GE-TX      103.74  2.47   103.74  2.47  on    on
4    WS-X6148A-GE-45AF   112.56  2.68   112.56  2.68  on    on
5    WS-SUP32-10GE-3B    175.98  4.19   175.98  4.19  on    on
6    (Redundant Sup)       -     -      175.98  4.19  -     -
7    WS-X6148A-GE-45AF   112.56  2.68   112.56  2.68  on    on
8    WS-X6148A-GE-45AF   112.56  2.68   112.56  2.68  on    on
9    WS-X6548-GE-TX      125.16  2.98   125.16  2.98  on    on
cat6509-wc1#
Furose M
Level 3
Level 3
looks like a power supply issue.. the power supply is currently in OFF state.
could you check if the power cable is working fine? if possible replace the power cable.
is there any other impact due to this error message?(like all the other moduels adn the PoE devices are working fine?)
I have already:
1.turn off/on;
2. fisically detach power suply;
3.change cable.
There are no other impacts.
Rosa
InayathUlla Sharieff
Rosa,
Kindly run the following command:
Switch#show environment st
power-supply 1:
  power-supply 1 power-output-fail: failed  >>Please check if you are seeing this error?if yes then replace the PSU.
Switch#sh environment alarm
environmental alarms:
system minor alarm on power-supply 1 power-output-fail (raised 2w0d ago) >>check this msg as well.
Inayath
cat6509-wc2#show environment st
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-9SLOT-FAN2
  fan-tray 1 version: 2
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 27C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 31C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 27C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC low
  power-supply 1 power-output-mode: low
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC low
  power-supply 2 power-output-mode: low
  power-supply 2 power-output-fail: OK
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 28C
  module 2 inlet temperature: 27C
  module 2 VDB outlet temperature: 28C
  module 2 VDB inlet temperature: 26C
  module 2 VDB device-1 temperature: 27C
module 4:
  module 4 power-output-fail: OK
  module 4 outlet temperature: 27C
  module 4 inlet temperature: 26C
  module 4 device-1 temperature: 24C
  module 4 device-2 temperature: 26C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 34C
  module 5 inlet temperature: 27C
  module 5 device-1 temperature: 35C
  module 5 device-2 temperature: 36C
  module 5 asic-1 temperature: 25C
  module 5 RP outlet temperature: 33C
  module 5 RP inlet temperature: 33C
  module 5 EARL outlet temperature: 35C
  module 5 EARL inlet temperature: 24C
module 6:
  module 6 power-output-fail: OK
  module 6 outlet temperature: 30C
  module 6 inlet temperature: 26C
  module 6 device-1 temperature: 27C
  module 6 device-2 temperature: 30C
module 7:
  module 7 power-output-fail: OK
  module 7 outlet temperature: 30C
  module 7 inlet temperature: 26C
  module 7 device-1 temperature: 27C
  module 7 device-2 temperature: 30C
module 9:
  module 9 power-output-fail: OK
  module 9 outlet temperature: 29C
  module 9 inlet temperature: 32C
  module 9 device-1 temperature: 26C
  module 9 device-2 temperature: 28C
cat6509-wc2#sh environment alarm
  no alarms
cat6509-wc2#
