SPAN - drops connectivity to destination
When I setup SPAN, I loose connectivity to the destination. I can’t remote into the destination computer to run Wireshark.  These are 2 switches acting in a stack.
switch(config)#do show monitor session 1
Session 1
Type : Local Session
Source Ports :
Both : gi4/0/45
Destination Ports : Gi1/0/26
Encapsulation : Native
Ingress : Disabled
balaji.bandi
if the port where the device connected - you enable span monitor this will be monitor port so you will loose access.
best is PC have 2 nic cards for you to remote in and monitor other connect for the span port (wireshark).
BB
6 Replies 6
Reza Sharifi
That is normal behavior of a SPAN destination port.
The state of the destination port is up/down by design. The interface shows the port in this state in order to make it evident that the port is currently not usable as a production port.
see link for further info:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10570-41.html#anc10
balaji.bandi
BB
Does this mean if Wireshark were already running on the destionation, Wireshark would still capture the packets even though I can not access the destination?
That is correct. Wireshark will capture the packets.
yes if your already running Wireshark on that port, and you have all the information capture on the destination device.
BB
