Span monitoring generate duplicate packets
bdecout
I'm trying to setup a span from two 6513 and have the folowing issue.
I have the two switch connected together with a channel-group trunk.
The span is limited to 128 ports on the 6500 so I can only use vlans as source.
I have the span traffic from each switch going into a span regenerator device than combines both source and send it out thru a single port onto my packets analyzer device.
My problem is that the traffic that enter Switch1 and goes to Switch2 is being spanned twice from each device because the channel-group trunk is part of the spanned traffic.
I couldn't find a way to exclude the trunk from the monitored traffic because I use Vlans as source instead of ports.
Any suggestion on how I can overcome this?
smalkeric
Level 6
Level 6
You can configure a trunk port as a source port. All VLANs active on the trunk are monitored.Refer URL
http://www-tac-rtp.cisco.com/Teams/ks/casekwery/casekwery.php?Case=E530502&tz=-330
