SPAN Not Capturing Packets
JaxIsland75
Community Member
My objective is to have port 17 mirror port 23 so I can use a laptop with Wireshark to see all the traffic on that port. I have not done this on a Cisco device before and I am using a 3560 v12.2(44)SE5. Using the below setup I see no traffic on the laptop connected to port 17. I have constant traffic being sent back and forth on port 23 and I can monitor the quantity with PRTG so I know there is data flowing through that port.
Here is what I have done:
3560G(config)#monitor session 1 source interface gigabitEthernet 0/23 both
3560G(config)#monitor session 1 destination interface gigabitEthernet 0/17
Here is more information:
Session 1
Type                   : Local Session
Description            : -
Source Ports           :
    RX Only            : None
    TX Only            : None
    Both               : Gi0/23
Source VLANs           :
    RX Only            : None
    TX Only            : None
    Both               : None
Source RSPAN VLAN      : None
Destination Ports      : Gi0/17
    Encapsulation      : Native
          Ingress      : Disabled
Filter VLANs           : None
Dest RSPAN VLAN        : None
interface GigabitEthernet0/17
 description Mirror_Port_23
 switchport access vlan 8
 spanning-tree portfast
GigabitEthernet0/17 is up, line protocol is down (monitoring)
Hardware is Gigabit Ethernet, address is 6416.8daa.f711 (bia 6416.8daa.f711)
Description: Mirror_Port_23
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:18:30, output 00:08:21, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 25000 bits/sec, 2 packets/sec
157301 packets input, 24296435 bytes, 0 no buffer
Received 4580 broadcasts (3880 multicasts)
0 watchdog, 3880 multicast, 0 pause input
360604 packets output, 260094573 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
interface GigabitEthernet0/23
 description Needs to be monitored
 switchport access vlan 2
 speed 100
 duplex full
GigabitEthernet0/23 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 6416.8daa.f717 (bia 6416.8daa.f717)
Description: Needs to be monitored
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
Last input never, output 00:00:00, output hang never
5 minute input rate 4000 bits/sec, 2 packets/sec
5 minute output rate 29000 bits/sec, 6 packets/sec
60371608 packets input, 6242172910 bytes, 0 no buffer
Received 570609 broadcasts (570467 multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 570467 multicast, 0 pause input
80487954 packets output, 96000984160 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Giuseppe Larosa
Hello JaxIsland75,
the span configuration is fine.
All the show commands are fine and the source and destination port are in different Vlans.
This is correct too on the destination port.
The port is sending out some frames
You source interface has option both meaning mirroring both TX and RX traffic
Now, the question is what do you see in your packet capture ?
If you see no frames captured you may have issues with wireshark installation (older wireshark versions use WinPCAP, new versions use NCAP, without these libraries installed you cannot capture)
Hope to help
Giuseppe
Giuseppe Larosa
Hello JaxIsland75,
Hope to help
Giuseppe
The packet capture was blank. There was nothing being captured on the wired port. I switched to the wireless and it would capture fine. This is a new installation of Wireshark that I downloaded and installed today. I rebooted the laptop and verified the wired port came up and now its capturing. I guess I should have been more confident in my config and just tried a reboot! Thanks for the response I appreciate it.
