SPAN on 6500 - maximum of 1 TX monitor interface(s)
kfarrington
Level 3
Level 3
Guys,
This cant be right can it? I want to monitor two ports on a ws-6724-sfp on a 5400 with a sup 720?
% This platform allows a maximum of 1 TX monitor interface(s)
Can it?
Many thx
Ken
6500switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
6500switch(config)#monitor session 1 source interface Gi2/1
6500switch(config)#^Z
6500switch#sh monitor
Session 1
Type : Local Session
Source Ports :
Both : Gi2/1
6500switch#conf t
6500switch(config)#monitor session 1 source interface Gi1/1
Session 1
Source Ports :
RX Only : Gi1/1
Both : Gi2/1
6500switch#conf t
owillins
Level 6
Level 6
This issue is due to the hardware limitations of Cisco Catalyst switches. Traffic monitoring in a SPAN session has these restrictions:
1. You can monitor incoming traffic on a series or range of ports and VLANs.
2. You can monitor outgoing traffic on a single port.
3. You cannot monitor outgoing traffic on multiple ports.
4. You cannot monitor outgoing traffic on VLANs.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html
NotMeHere
You need to include a "show ver" with your post, but this is the general guidelines:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html#wp1020356
