SPAN On Cisco Nexus System version 9.3(13) - Dst in wrong mode
Gabriel Voitis
Metro.1.New# show monitor session all
session 1
type : local
state : down (Dst in wrong mode)
acl-name : acl-name not specified
source intf :
rx : Eth1/6
tx : Eth1/6
both : Eth1/6
source VLANs :
rx :
tx :
both :
filter VLANs : filter not specified
source fwd drops :
destination ports : Eth1/8
source VSANs :
rx :
Metro.1.New# show interface Ethernet1/8 capabilities
Ethernet1/8
Model: N9K-C93240YC-FX2
Type (SFP capable): 1000base-T
Speed: 100,1000,10000,25000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated
Port mode: Routed,Switched
QOS scheduling: rx-(8q2t),tx-(7q)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
MDIX: no
TDR capable: no
Link Debounce: yes
Link Debounce Time: yes
FEX Fabric: yes
dot1Q-tunnel mode: yes
Pvlan Trunk capable: no
Port Group Members: 8
EEE (efficient-eth): no
PFC capable: yes
Buffer Boost capable: no
Breakout capable: no
MACSEC capable: yes
Metro.1.New# sh int e1/8
Ethernet1/8 is up
admin state is up, Dedicated Interface
Hardware: 100/1000/10000/25000 Ethernet, address: 4c77.6dfb.e461 (bia 4c77.6dfb.e469)
Description: nprobe eno1
MTU 1500 bytes, BW 1000000 Kbit , DLY 10 usec
Encapsulation ARPA, medium is broadcast
full-duplex, 1000 Mb/s, media type is 1G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is off
Last link flapped 00:08:17
7 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 0 bits/sec, 0 packets/sec
300 seconds output rate 0 bits/sec, 0 packets/sec
RX
4 unicast packets 62 multicast packets 34 broadcast packets
100 input packets 18716 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
4 unicast packets 96 multicast packets 0 broadcast packets
100 output packets 17420 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Metro.1.New#
Thank you,
Gabe
Gabriel Voitis
All good now.
Metro.1.New(config-if)# switchport ?
<CR>
access Set access mode characteristics of the interface
autostate Include or exclude this port from vlan link up calculation
block Block specified outbound traffic for all VLANs
dot1q Configure dot1q EtherType value
host Set port host
isolated Disable loop-free detection.
mode Enter the port mode
monitor Configures an interface as span-destination
trunk Configure trunking parameters on an interface
virtual-ethernet-bridge Enable hair-pin forwarding
vlan Set VLAN translation mapping
Metro.1.New(config-if)# switchport monitor
Metro.1.New(config-if)# end
Gabe
