SPAN port cisco 9400 troubleshooting
byrollo rg
I want to set up a SPAN port on cisco 9400 for future troubleshooting, to capture *all* core traffic (important: all trunk/access ports), so that I can analyze it with a wireshark installed on notebook PC in port 6/0/38.
I have 2 questions:
- is the PORT SPAN configuration correct?
monitor session 1 source vlan 1 - 1000
monitor session 1 destination interface Gi6/0/38 encapsulation dot1q
- is it correct to put the destination port in TRUNK or is it more correct in ACCESS?
interface GigabitEthernet6/0/38
description SPAN Port Troubleshooting
switchport mode trunk
thanks in advance
9 Replies 9
balaji.bandi
I saw the link, but I can't find the answer to my 2 questions, can you help me please?
switchport mode  access
BB
But does this apply regardless of how "Encapsulation Mode" is set on destination port?
In order to capture all the traffic is it better to have DOT1Q or REPLICATE?
In my case I set it this way:
SW#show monitor session 1
Type                     : Local Session
Source VLANs             :
    Both                 : 1-1000
Destination Ports        : Gi6/0/38
    Encapsulation        : DOT1Q
          Ingress        : Disabled
monitor session session-number destination { interface interface-id [ , | -] [ encapsulation { replicate | dot1q} ] }
encapsulation replicate:
 - Specifies that the destination interface replicates the source interface encapsulation method. If not selected, the default is to send packets in native form (untagged).
encapsulation dot1q:
 - Specifies that the destination interface accepts the source interface incoming packets with IEEE 802.1Q encapsulation.
Thank you so much for help
can someone please clarify this for me?
this should work for you, until we misunderstand your requirement,
BB
usman ali dar
Hi you dont have to mention anything for the destination port just leave it in NoShut mode and thats it
Reza Sharifi
Yes, that is correct but I would use the actual number of VLANs you have on the switch e.g 5, 10, 20, etc., and not 1000.
The destination port (g6/0/38) is where your laptop will be connected and needs to be configured as an access port.
Hi, My apologies i was thinking you are using Nexus; in CATOS we will just configure the port "switchport mode access" and in nexus we use "switchport monitor"
