Span port limit
nawas
Level 4
Level 4
How many source ports can be ideally spanned to one destination port? we are planning to use an application in our serverfarm switch but looks like I will have to span more than 20 source ports to one destination, is it doable or recommended way? Is there any Cisco doc that tells us the statistics or utilization for the span ports?
Edison Ortiz
All depends upon the amount of traffic being sent from those 20 source ports. Any exceeded traffic will be dropped without affecting switch performance. This documentation has comprehensive information regarding SPAN on several Catalyst switches
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
HTH,
__
Edison.
5 Replies 5
Edison Ortiz
HTH,
__
Edison.
nawas
Level 4
Level 4
I have another question, I'm runing hybrid mode on SUP720 and I don't think I can span a vlan in CAT OS, correct?
Did you actually read the link I posted?
I think I posted second question too early, I got the link, thank you for your help
Glad to help
Please remember to rate helpful posts
