SPAN session and IGMP reports
jussivee
I have an issue trying to capture IGMP reports from a client. I can see the IGMP queries and multicast towards the client. The client is also sending out multicast which I can see, but IGMP reports from the client are not showing up.
Cisco 3560G version 12.2(37)SE
interface GigabitEthernet0/6
switchport access vlan 226
switchport mode access
no ip igmp snooping tcn flood
end
interface GigabitEthernet0/12
no switchport
no ip address
end
monitor session 1 source interface Gi0/6
monitor session 1 destination interface Gi0/12
The client is sending out IGMP reports:
226       231.231.231.231          igmp                    Gi0/6
Monitoring with Wireshark 1.10.2 and Intel 82567LM Gigabit Network adapter.
jeffrrod
Level 4
Level 4
Dear Jussi-Pekka,
Thank you for reaching the Small Business Support Community.
I am afraid to tell you you posted your request for support on the wrong community forum, the Cisco3560 is considered an enterprise device and therefore I suggest you to move over this post to the "LAN, Switching and Routing" forum using the "Action" panel on the top right corner of this window or just open up a new threat;
https://supportforums.cisco.com/community/netpro/network-infrastructure/switching
I apologize for the inconvenience and please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
