span source interface is not working as intended in NX-OS
lchan007
I set up SPAN in nxos switch to capture all traffic (specific interest on one vlan) on switchport Eth25,26,27.
Eth24 is plugged into a Linux server with tcpdump running and it is running as the destination. However, the capture doesn't see anything except for multicast traffic until I specific vlan as the source interface.
I expect the interfaces as source would capture all traffic, but it is not working. What am I missing?
Not Working
monitor session 2
  source interface Ethernet1/25 both
  source interface Ethernet1/26 both
  source interface Ethernet1/27 both
  destination interface Ethernet1/24
  no shut
Workaround
monitor session 3
  source interface Vlan802 both
  no shut
Partial Config
! Software
!   BIOS: version 07.64
!   NXOS: version 7.0(3)I7(5a)
!   BIOS compile time:  05/17/2018
!   NXOS image file is: bootflash:///nxos.7.0.3.I7.5a.bin
!   NXOS compile time:  10/12/2018 19:00:00 [10/13/2018 03:16:04]
vlan 1,11,21-26,35,90,92,120,162-167,802,2511-2512,2715-2716,2725-2726,2735-2736,2795-2796,3010-3011,3025-3026,3035-3036,3055-3056,3085-3086,3095-3096
interface Ethernet1/24 description SPAN interface Ethernet1/25 description octrl-1-1:eth7 switchport switchport access vlan 802 spanning-tree port type edge no shutdown interface Ethernet1/26 description octrl-2-3:eth7 switchport switchport access vlan 802 spanning-tree port type edge no shutdown interface Ethernet1/27 description octrl-2-2:eth7 switchport switchport access vlan 802 spanning-tree port type edge no shutdown
interface Vlan802 description openstack-dmz:neutrongw no shutdown mtu 9216 vrf member openstack-dmz no ip redirects ip address 10.241.193.195/28 ip address 10.146.71.3/25 secondary hsrp version 2 hsrp 802 name openstack-dmz:neutrongw preempt delay minimum 5 reload 60 sync 15 priority 110 timers 1 5 ip 10.146.71.1
Reza Sharifi
Are ports e1/25, 26 and 27 supposed to be part of
context?
e1/25-27 is part of an SVI. Vlan802 is part of the vrf openstack-dmz
if the VLAN belong to X VRF. and Destination port is in Global Interface right ?
Can you post monitor session config also. ( i do not re-call the syntax long back tested - try to dig later at my archieve)
check there is vrf configure required in the monitor session.
BB
BB,
I posted the monitor sessions in the first post, will add the actual config when I get a chance. The only difference is I set the source as the vlan, both don't have vrf configure on the monitor session.
