Spanning Tree configuration help
grapevine
Level 5
Level 5
I have a Cisco IE 4010 running MST connected to cisco IE 9320 running PVST connected via a single port. IE 9320 has a priority 24576 and IE 4010 has a priority 32768. Since they are running different mode of STP, that trunk port is getting blocked on Cisco IE 4010. the logs I see on Cisco IE 4010 is
%SPANTREE-2-PVSTSIM_FAIL: Blocking designated port Gi1/13: Inconsistent superior PVST BPDU received on VLAN 23, claiming root 24599:5000.e0e7.8380
6 Replies 6
Mark Elsen
   - @grapevine             All switches in the network must use the same spanning tree algorithm
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
aleabrahao
Meraki Community All-Star
You should have to run the same spanning tree mode on both switches.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
grapevine
Level 5
Level 5
Would running this command on ie 4010 fix the issue
conf t
spanning-tree mode pvst
end
  - @grapevine                           Yes ,
  M.
Hello @grapevine ,
I would recommend
spanning-tree mode rapid-pvst
PVST uses non Rapid STP instances. Rapid PVST uses Rapid STP instances.
on all switches
Hope to help
Giuseppe
Hello
Looks like you are showing a pvst simulation issue that’s blocking those ports
Most preferred approach if you wish to continue to run with the two stp regions(MSTP/PVST+) is firstly make sure your mst instances have all the vlans that exist in the pvst+ region.
Then all your mst instances (especially instance 0) stp priorities must become the most preferred (set to a lower value) than ALL of your PVST+ vlans.
This will make MST root switch become the CIST root switch for the entire STP estate.
However if you wish to have the PVST+ region to be the CIST root for the whole stp estate, then the PVST+ vlan priorities need to be change to accommodate PVST+ simulation rules, meaning ALL vlans require to have a lower stp priority of all the MST instances (including mst 0) AND most importantly
PVST+ vlan 1 has to be of a less preferred value then all the other PVST+ vlans in that region.
Example PVST+ CIST root:
PVST+  vlan1 = 4096 ,  vlan2 + = 0
MST x =  8192
Kind Regards
Paul
