Spanning tree in firewalls and switches
dhanushkas
Hi Team,
Please be kind enough help me to clear my doubt.
We have two stacked switches connecting to a firewall and both switches are connected through single port channel. Port channel is configured as a layer two trunk.
Can anyone let me know will firewall send BPDUs to the switch and participate STP.
Thank you and Regards,
Gayan Samarakoon.
marce1000
- Normally not because the firewall is not part of the layer2 domain and or usually you will access it by routing solutions
 M.
6 Replies 6
marce1000
 M.
Hi Marce,
Is it advisable to configure Port fast and BPDU guard on the interfaces connecting to firewall.
Thank you,
Dhanushka
        - Portfast YES, BPDU guard no.
 M.
Hi Marce,
Thanks a lot for your prompt reply.
Any reason, why we can not enable BPDU guard on those interfaces, Can we enable Root guard on those interfaces?
Thank you,
Dhanushka.
                   - Revisit my initial reply.
 M.
If FW is transparent mode,
Then yes it will forwarding bpdu receive from one SW to other.
