Spanning tree instance(s) for vlan (X) does not exist
Murad*
Level 5
Level 5
i faced this problem when i tried to show the root bridge ?!
what the reason of that ?
and how i can fixed that ?
Deepak Kumar
You are using the wrong command to view SPANNING-TREE.
Show spanning-tree active or Show spanning-tree
The command "Show VTP status" for check the VTP (VLAN Trunking Protocol) status. Both are the different protocols.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
no its not wrong , the vlan active in the switch , and other vlan work normally and this command work with other vlan .
Please share Switch model number and IOS version.
Deepak Kumar
Deepak Kumar,
C3750 , c3750-ipbase-mz.122-25.SEB4
