Spanning Tree Protocol and Backup Ethernet Interface
akhasapetyan
Community Member
When we enable backup interface on interface by issuing command "ethernet backup interface" the spanning tree protocol stops functioning. The mentioned hardware is:
cisco ASR-920-24SZ-IM (Freescale P2020) processor (revision 1.2 GHz) with 893202K/6147K bytes of memory.
Processor board ID CAT2316V0MM
24 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1231647K bytes of eMMC flash at bootflash:.
Cisco IOS XE Software, Version 16.11.01a
Cisco IOS Software [Gibraltar], ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 16.11.1a, RELEASE SOFTWARE (fc1)
Could someone help us to shed a light on this issue?
Hello
I assume this is in indeed a L2 interface as you mentions spanning-tree, If so when applying a flex-link by default stp is disabled on that interface.
Kind Regards
Paul
