spantree blocing question
king-1195
Now, my two 3548 switchs each have two trunk uplink connectting to core 6509
switch,the two link are made into port channel.But I find that in one 3548, one
link's spantree status is blocking and the other is forwarding. In the other 3845s two link's spantree status is fordwarding. Why ?
the 6509 informaiton as following:
Port Mode Encapsulation Status Native vlan
4/2 nonegotiate dot1q trunking 1 (to 3548_1 G0/1)
4/3 nonegotiate dot1q trunking 1 (to 3548_2 G0/1)
5/2 nonegotiate dot1q trunking 1 (to 3548_1 G0/2)
5/3 nonegotiate dot1q trunking 1 (to 3548_2 G0/2)
Port Vlan Port-State Cost Prio Portfast Channel_id
4/2 1 forwarding 4 32 disabled 0
4/3 1 forwarding 4 32 disabled 0
5/2 1 blocking 4 32 disabled 0
5/3 1 forwarding 4 32 disabled 0
set spantree priority 8192 1
set spantree priority 8192 76
set port channel 4/2,5/2 386
set port channel 4/3,5/3 387
set trunk 4/2 nonegotiate dot1q 1-1005,1025-4094
set trunk 4/3 nonegotiate dot1q 1-1005,1025-4094
set trunk 5/2 nonegotiate dot1q 1-1005,1025-4094
set trunk 5/3 nonegotiate dot1q 1-1005,1025-4094
the 3548 informaiton as following:
sh spanning-tree interface g0/1
Interface Gi0/1 (port 67) in Spanning tree 1 is FORWARDING
Port path cost 4, Port priority 128
Designated root has priority 8192, address 0001.c74e.8000
Designated bridge has priority 32768, address 0005.32f5.8280
Designated port is 67, path cost 19
Timers: message age 0, forward delay 0, hold 0
BPDU: sent 690720, received 99
Interface Gi0/1 (port 67) in Spanning tree 76 is FORWARDING
Designated root has priority 8192, address 00d0.00cf.3c4b
Designated bridge has priority 8192, address 00d0.00cf.3c4b
Designated port is 194, path cost 0
Timers: message age 1, forward delay 0, hold 0
BPDU: sent 5, received 365139
sh spanning-tree interface g0/2
Interface Gi0/2 (port 75) in Spanning tree 1 is FORWARDING
Designated port is 75, path cost 19
BPDU: sent 689667, received 14
Interface Gi0/2 (port 75) in Spanning tree 76 is BLOCKING
Designated port is 2, path cost 0
BPDU: sent 2, received 365135
ankbhasi
Hi King,
Can you post the configuration for your 3500Xl also?
Ankur
kamal-learn
Level 4
Level 4
hi
can you post the (show port channel X)
where X is 4/2, 4/3, 5/2, 5/3 separately from your 6509.
it seems that the etherchannel does not form!!!
channel-id is 0 as you posted!!!
Francois Tallet
Level 7
Level 7
The way I imagine your network from your description, you now have 4 bridges in a ring. One link needs to be blocked, not two. If you add a third access bridge, a second port will block. If you add a link between the two core, another link will block, etc...
Francois
