speed negociation delay
VALERIE LOISEL
Community Member
I've got an infrastructure with gigabit 4500 switch and connected machines.
Machines connected with standard twisted cable (4 pairs) works fine and negociate quite instantly to G : no problem.
When have to split one plug and connect 2 machines (2 paris for each), the speed is negociated to 100M full : no problem concerning the speed, but it seems that the process of the negociation itself is quite long and so, the port makes quite a long time to come up (up to 10-20 seconds).
The problem is that when I fix the speed on the switch port, the connection does not work (speed is configured in auto mode on my machines and I cannot change that).
Is there any possibility to decrease this delay of speed negociation ?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What might be the cause of that, many of the newer ports are also auto MDI/MDI-X when auto is enabled but not when auto is disabled.  Try swapping tx/rx pair.
