traffic-export capturing only inbound traffic
colintaylor
We have a Cisco 2811 running ITP IOS.  On that router we run the SMPP service.  A client on the network connects to this service, and we need to capture the traffic for debug.
I've tried traffic-export, but I cannot see any outbound traffic.
I'm guessing that this is due to the fact that the outbound SMPP traffic is not transit traffic as it is generated by the router itself.
Is there any way to capture the outbound traffic?
Colin
Bilal Nawaz
Hi Colin,
Please see below
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_usr_cfg/configuration/12-4/sec-ip-traff-export.html
Step 8
outgoing            {access-list{standard | extended | named} | sample one-in-every packet-number}
Example:
Router(config-rite)# outgoing sample one-in-every 50
(Optional) Configures filtering for outgoing export traffic.
Note   If you issue this command, you must also issue the bidirectional  command, which enables outgoing traffic to be exported. However, only  routed traffic (such as passthrough traffic) is exported; that is,  traffic that originates from the network device is not exported.
An option might be to plug in to a cisco switch and SPAN the port to an interface with a sniffer on it like wireshark?
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#topic4
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
Hi Colin,
Please see below
Step 8
Example:
Thanks Bilal.
Capturing externally was something I had considered as a fallback for half the problem.
The other issue is that the SMPP service also connects to a supplier over IPSEC - and that traffic is what we expect to be wrong.  We would have to export the traffic that was router-generated, but that doesn't look possible.
it is possible  to get router-generated traffic with enhanced packet capture.
https://supportforums.cisco.com/docs/DOC-5799
Alain
Thanks Alain
I tried this out on my test 1841 running c1841-advipservicesk9-mz.151-2.T4.bin, and it seems to work, with the exception that I can only view the dumps on the console, the IOS doesn't seem to support copying to TFTP etc for viewing in wireshark.
Then I tried it on the production router, a 2811 running c2800nm-itpk9-mz.124-15.SW9.bin.  the "monitor capture" command suite is not available on that ISO.  D'Oh!
Thanks for the input though, I learnt something new.
Colin
