Speed VS Bandwith
Krishnendu AR
Hi Guys,
AS100-R1(config-if)#bandwidth ?
  <1-10000000>  Bandwidth in kilobits
  inherit       Specify that bandwidth is inherited
  receive       Specify receive-side bandwidth
AS100-R1(config-if)#speed ?
  10    Force 10 Mbps operation
  100   Force 100 Mbps operation
  auto  Enable AUTO speed configuration
What is the difference between Speed and bandwidth command at the interface level?
Krishna
       Bandwidth is used to reference for calculation things such as routing protocols, output of show commands.
       Speed is used to tell the interface to send actual packets at the rate you configured. Such as 10 Mbps is what the swicth can send 10Megabit per second.
HTH,
Toshi
