SRR - Shape and Share command on interface
voiper_99
Level 4
Level 4
Hi, I am having trouble understanding the following configuration:
srr-queue bandwidth share 10 10 40 40
srr-queue bandwidth shape 100 0 0 0
queue-set 2
The Cisco documentation says "If the egress priority queue is disabled and the SRR shaped and shared weights are configured, the shaped mode overrides the shared mode for queue 1, and SRR services this queue in shaped mode" so why would anyone bother configuring both a shaped and a shared mode if the shaped is going to take priority?
royalblues
Level 11
Level 11
Because the weight ratios for queues 2, 3, and 4 are set to 0, these queues operate in shared mode. The bandwidth weight for queue 1 is 1/100, which is 1 percent
Narayan
I see. Where does the formula 1/100 come from?
