SSH and Telnet both in boot flash
thaman303
Hello Experts,
Can some one please help me how can I put SSH and Telnet both in bootflash.
Best Regards
Telnet is supported on all the IOS images. To support SSH on you 1841 router you need the following image: c1841-ipbasek9-mz.124-1c.bin . I have checkd and it meets the minimum DRAM and Flash requirement on you router. So go ahead and load the IOS that I mentioned above and you will be good to go.
HTH,Please rate all the posts.
-amit singh
8 Replies 8
Amit Singh
What do you mean by pushing SSH and telnet both in bootflash.
Is it that you want to have an IOS which supports SSH and telnet.
or you want to enable the SSH and telnet on the BOX.
If its the later, then you can simply configure the line vty to allow the SSH and telnet on the box, after configuring the basic settings.
Line vty 0 4
transport input ssh telnet
If you want the IOS then please paste the show version from your box and we will suggest accordingly.
Please see the links below for more info:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a0080094314.shtml
HTH,please rate if it does.
-amit singh
Thanks much Amit. I want IOS which support Both telnet and bootflash.
Here its sh version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
yourname uptime is 3 minutes
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FTX1121W205
2 FastEthernet interfaces
1 Serial interface
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Rds
-amit singh
thanks much Amit. I have that image file.
Another Q if you have time please we have 1721 router so what image would be for that one ? Rds
its will be the K9 images which supports SSH. Please paste the show version from your 1721 router and I will assist you.
You can alo findout the supported feature/release for a particular router by using the Cisco's feature navigator tool. Please find the link below and it will be of great help in near future for IOS selection.
http://www.cisco.com/go/fn
HTH,Please rate if it does.
-amit singh
Amit , here it is
IOS (tm) C1700 Software (C1700-Y-M), Version 12.3(9c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 01-Dec-04 01:13 by kellythw
Image text-base: 0x80008120, data-base: 0x809F74EC
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
70402_Dixon uptime is 2 days, 1 hour, 35 minutes
System image file is "flash:c1700-y-mz.123-9c.bin"
cisco 1721 (MPC860P) processor (revision 0x400) with 54395K/11141K bytes of memo
ry.
Processor board ID FOC08471G81 (1352093102), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Rds and Thanks a lot
Here is the image that you need c1700-advsecurityk9-mz.123-9c.bin . Download it and you are all set to go. It meets the DRAM and flash requirement that is there on your router.
-amit singh
Thanks Amit again.
Rds
