ssh automate on multiple switches
hi all,
I am looking to automate ssh on multiple cisco switches with bash script, and after the login, can execute commands, like:
conf t
vlan 10
name IT
end
wr
ex
Anybody know if there are some good scrips, or examples anywhere to get me started?
Many thanks in advance
9 Replies 9
Jon Marshall
Does it have to be shell script because for this sort of thing Python is becoming the choice of scripting language.
There is also a module written for Python called Netmiko which deals specifically for automating logging into network devices -
https://pynet.twb-tech.com/blog/netmiko-python-library.html
Jon
I have tried wit python and paramiko, but did not work on jumpserver of the businessworkbook.
What exactly didn't work ?
Jon
I could not install the paramiko package
Difficult to say without understanding what OS you are trying it on, what the error message was etc.
You can find examples of using shell scripts with a bit of searching but honestly sorting out your Python install would make a lot more sense in the long run if you want to look at more automation.
Jon
okay, I am going to copy all info here, tomorrow, after I started my workbook
balaji.bandi
There is good tool you can use with Python :
https://github.com/albertsuwandhi/Cisco-Tools
BB
unfortunately python does not work, but thanks
Try shell script :
https://community.cisco.com/t5/switching/script-to-automate-tasks/td-p/1950293
BB
