SSH connection not possible on WAN link
cbonnal35
I've a problem with my 871W.
I can connect to the router by inside interfaces (LAN & WLAN) but not on WAN (Fa4).
My client on the WAN is on the same subnet and I can ping 871.
Can you tell me what's wrong in my config ?
Thank you!
ALIAOF_
Level 6
Level 6
You are trying to SSH to your router using its Public IP address from another location?
WAN interface is DHCP client on my company network. So it get 10.33.4.x as WAN IP address.
My SSH client (me), is on company network too, and have also an IP address on 10.33.4.0/22 subnet.
Ping is OK but SSH timeout.
Do you have an idea ?
Try removing all those Deny statements from "ACLPrincipale" and see if it works first, then add them one by one and see which one is causing the issue.
