WS-C3560G-48PS-S 15.0(1)SE2 ipbase no 802.1x interface commands...
neal.alberda
Confused.. I know commands changed in 15 from dot1x ... to authentication ... etc.  I have this working on oth 2960S's, but on this 3560G, I have no "authentication" or "dot1x" commands on a per port basis..
sh run <snippit>
aaa new-model
aaa authentication enable default enable
aaa authentication dot1x default group radius
aaa authorization console
aaa authorization exec default local if-authenticated
aaa authorization commands 15 default local if-authenticated
aaa authorization network default group radius
dot1x system-auth-control
radius server rad1
raduis server rad2
Then I attempt:
cgp1-swa01#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
cgp1-swa01(config)#dot
cgp1-swa01(config)#dot1x ?
  credentials          Configure 802.1X credentials profiles
  critical             Set 802.1x Critical Authentication parameters
  guest-vlan           Configure Guest Vlan and 802.1x Supplicant behavior
  logging              Set logging parameters
  supplicant           802.1X supplicant configuration
  system-auth-control  Enable or Disable SysAuthControl
  test                 Configure dot1x test related parameters
cgp1-swa01(config)#dot1x sy
cgp1-swa01(config)#dot1x system-auth-control
cgp1-swa01(config)#int gi0/12
cgp1-swa01(config-if)#auth?
% Unrecognized command
Any thoughts?  Am I missing something to enable this functionality, or is my switch not capable??
Cheers.
5 Replies 5
Sandeep Choudhary
Hi Neal,
Here are the features supported by this software on this platform:
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Go to search by software then select IOS, select 15.0SE, release 15.0(1)SE2 then choose platform and feture set.
REgards
Please rate if it helps.
Well, thanks for that.  It confirms that the features should be supported by the IOS/hardware, however my problem of the commands not being recognized still exists.
Any thoughts?
What version of IOS are you running?  This feature should be supported in IP Base image.
Here is sh ver form a 3750 running IP Services that supports Authentication command under the interface.
System image file is "flash:/c3750e-universal-mz.122-52.SE/c3750e-universal-mz.122-52.SE.bin"
Switch(config)#dot1x system-auth-control
Switch(config)#inter gi1/0/2
Switch(config-if)#auth
Switch(config-if)#authentication ?
  control-direction  Set the control-direction on the interface
  event              Set action for authentication events
  fallback           Enable the Webauth fallback mechanism
  host-mode          Set the Host mode for authentication on this interface
  open               Enable or Disable open access on this port
  order              Add an authentication method to the order list
  periodic           Enable or Disable Reauthentication for this port
  port-control       Set the port-control value
  priority           Add an authentication method to the priority list
  timer              Set authentication timer values
  violation          Configure action to take on security violations
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560G-48PS     15.0(1)SE2            C3560-IPBASEK9-M
I'm still confused.. this works on a 2960S (same IOS ver).
Well thats annoying...
Step 9
swtichport mode access
(Optional) Set the port to access mode only if you configured the RADIUS server in Step 6 and Step 7.
That isn't optional (otherwise there are no interface authentication commands).
