Showing results forĀ
Search instead forĀ
Did you mean:Ā
SSH is working very slow during base build
Hi Experts
I am doing the base build of switches in stack  C9200L048T-4x. SW : 17.06.03.
I am configuring the basic ssh to build switches and problem is : when i accessing this switch through other switch locally then login response and running the command on switch is fast. when i am accessing the switched through WAN then response to switch in terms of accessing and running the commands on it is very slow.
below is basic config (XXXX is placeholder) which i applied on it. Moreover, the same config is working fine on other new switches , only problem with this particular switch.
no aaa-model
enable secret XXXXXX
username XXXXX password YYYYY
ip domein name XXXXXXX
ip ssh version 2
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
Gurbinder
SSH is encrypt decrypt so if the CPU face high utilize then the SSH is slow.
thanks for your reply, but cpu utilization is very normal
CPU utilization for five seconds: 1Percent/0Percent; one minute: 1Percent; five minutes: 1 Percent
are you slow in SSH login or slow to enter commend ?
Hi Experts
I have been working on this since morning and did some research and fixed it.
@MHM: yes it was both during login and command run.
Solution I applied: So routing can be the one of the issues to make it slow. there was default route missed towards my core switches. After apply that now it is working normally. if anyone of you face this type of problem then please check this one thing as well.
Thanks for your support and Guidance
Gurbinder
