SSH issue to 3850 switch
ittechk4u1
Level 7
Level 7
Hello experts,
We arenot able to ssh to our new core switches:
Switch: 3850
Software version: 16.3.5b
Error:
350259: Jun 11 08:23:48: %SSH-3-NO_MATCH: No matching kex algorithm found: client diffie-hellman-group1-sha1 server diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
How can we solve that issue?
I saw there is a bug but no resolution :  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc96144/?rfs=iqvred
Thanks in advance.
17 Replies 17
johnd2310
Level 11
Level 11
Have you tried using a 1024 bit key? You can use the following command to generate 1024 bit key:
crypto key generate rsa general-keys modulus 1024
John
**Please rate posts you find helpful**
Reducing the key to 1024 didn't work in this scenario.
still not working....
or even try lower , crypto key generate rsa general-keys modulus 512 works for me
Hello
What kind of key do you have - Have you tried deleting it and regenerating a new one ?
crypto key zeroize rsa
res
Paul
res
Paul
Kind Regards
Paul
yes i did.....still the smae issue..
[SSH] Protocol Version 2 (Cisco-1.25)
[SSH] FAIL: no kex alg
[SSH] INFO: DISCONNECT"
where is the SSH coming from, that is, what are you using as client ?
The issue I'm experiencing is from switch to switch - all switches in the environment use RSA 1024.
I am able to initiate a SSH session from my workstation without issue.
can you try and create a modulus 2048 key and then configure:
ip ssh dh min size 2048
Also, just to be sure, check if you have all of the below configured:
hostname myswitch (needs to be different than the default hostname)
username admin privilege 15 password 0 cisco
enable secret xxxxyyyy
ip domain-name yourdomain
crypto key generate rsa general-keys modulus 2048
ip ssh version 2
line vty 0 15
login local
transport input ssh
Thank you for the input - unfortunately I cannot modify production devices - the WS-C3850-12S-S (Denali - 16.3.5b) that's receiving error was an addition to our network.
To answer your questions, yes, all the following are configured:
uniqueHostname
username admin priv 15 password ***
enable secret ***
ip domain-name example.net
aaa new-model
aaa authentication login default local
aaa authorization exec default local
crypto key gen rsa mod 1024
ip ssh ver 2
ip ssh logging events
line vty 0 4
login local
transport input ssh
I tried, still not working!!!!
Update: SSH is working on putty but not on ZOC terminal emulater!!
Thanks again.
 What ssh client are you using?
John
try to add 3des-cbc algorithm in ip ssh server command for input ssh sessions & 3des-cbc algotithm in ip ssh client command for ouput ssh sessions
regards
I am having this same issue connecting with SecureCRT 5.0.5 build 1078. I can however SSH -l from their router to the same switch without issue. We just updated Prime to 3.1 and the sync is basically reporting it to cannot connect to pull the config. I did try redoing the crypto keys to 1024 and it did not change the issue. I am going to try to see if my newer version of SecureCRT does the same thing.
Brent
