SSH Modulus issue
Anand Thakur
Level 2
Level 2
I have a 3925 router Version 15.2(4)M5 which is being used for terminating a back up Internet link and will be used to SSh the internal devices from outside in cas eht e primary link fails.
All the internal devices are reachable from the router through SSH but only a one cisco small business switch is not reachable with the following error:
ssh -l inat8222a 172.30.41.3
[Connection to 172.30.41.3 aborted: error status 0]
%SSH-3-INV_MOD: Invalid modulus length
The following log is generated on the 3925 router after the connection fails:
What needs to be changed in order to make this connection successful.
Thanks in advance.
Reagrds,
Anand
acampbell
Anand,
can you look at
show ip ssh
on your 3925 - you should see something like this:-
#sh ip ssh
SSH Enabled - version 1.99
Authentication timeout: 15 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 1024 bits
You need to know what length the key should be set too from
the SSH host you are using
http://www.cisco.com/c/en/us/support/docs/security-vpn/secure-shell-ssh/4145-ssh.html
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hello Alex,
I can see the following on the SSH source cisco 3925:
sh ip ssh
SSH Enabled - version 2.0
Authentication timeout: 60 secs; Authentication retries: 3
IOS Keys in SECSH format(ssh-rsa, base64 encoded):
On the target cisco sg-500 switch i can see the following:
sh ip ssh
SSH Server enabled. Port: 22
RSA key was generated.
DSA(DSS) key was generated.
SSH Public Key Authentication is disabled.
Anand
Anand,
On your 3925 can you try adding this line to your config:-
ip ssh dh min size 4096
Alex.
