SSH to Cisco Catalyst Switch
Can someone please tell the commands to setup SSH to a Catalyst 3560 switch? This will be to the private IP Address
Any help will be greatly appreciated.
Lake
6 Accepted Solutions
Jon Marshall
Lake
See this document for details on configuring ssh -
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
basic steps -
configure hostname
configure domain name
configure username
create crypto key
enable vty lines for ssh
note that your image name must have a k9 in it as this is the image version that supports ssh.
switch# dir flash:
will show you the image name
Jon
Hi Lakeram,
SSH needs the K9 image in the switches. Please go ahead and download the K9 image of the c3560-ipbasek9.mz(exact version) from the Cisco software download page to enable SSH. You could easily upgrade to an IOS with Krypto Image as it doesn't need purchasing any license(Most of the times). It is only required when you upgrade from to a different feature set for example from IPBASE to IPSERVICES.
Ricky Micky
*Pls rate useful posts
Lake
You have downloaded the new IOS image but you are still running the old image ie. from your output -
System image file is "flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin"
so you need to tell the switch to boot the new image. Firstly you need to locate the new image ie. it will be in flash but if you notice from the above the actual .bin file is in a directory
directory = c3560-ipbase-mz.122-25.SEE2/
actual image file =  c3560-ipbase-mz.122-25.SEE2.bin
if you do a "dir flash:" you will see the directory and in that directory is the actual image file.
It depends on how you loaded the new k9 image. If you loaded he whole directory then you need to use the directory/filename but if you just loaded the actual image file ie. the .bin file then you just use the image name.
To tell the switch which image to boot add this to your config -
boot system flash flash:c3560-ipbasek9-mz.122-25.SEE2/c3560-ipbasek9-mz.122-25.SEE2.bin
the above would be if the new image was in a directory. If it's just file then don't include the directory bit. Note be very careful when entering the above as it needs to match exactly.
One last point. There may already be a boot system flash command in your running config. If there is -
1) remove it with the "no boot system flash ......" command
2) then put the new one in and then add the old string after that separating with a semicolon eg.
boot system flash flash:c3560-ipbasek9-mz.122-25.SEE2/c3560-ipbasek9-mz.122-25.SEE2.bin;flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
Jon
Lake,
The command is
crypto key generate rsa
ip ssh time-out 60
ip ssh authentication-retries 2
Here is doc to that goes over the SSH installation and how to configure your PC for SSH access
Reza
line vty 0 15
transport input ssh or all...
I usually set to ssh only...
Cheers,
Fabio
if I were you I would do this
username xxx privilege 15 secret xxxxx
line vty 0 15
no  password password
login local
Cheers,
Fabio
17 Replies 17
Jon Marshall
Lake
basic steps -
configure hostname
configure username
create crypto key
switch# dir flash:
Jon
Hi Jon,
I will test and let you know.
Lake
Jon
When i enter the dir flash: It says c3560-ipbase-mz. How can i upgrade to k9?
Lake
Hi Lakeram,
Ricky Micky
I will do that.
Lake
There is no crypto command on the 3560 switch even though k9 software. Can someone please help me with this?
Lake
Lake
Are you sure you are running the k9 image. Can you post a "sh ver" ?
Jon
Lake
Jon
Jon
That worked
Thank you very much.
Lake
Can you please tell me the full crypto key command?
Lake
Lake,
The command is
ip ssh time-out 60
Reza
That worked.
what is the command to enable vty lines for ssh? Can someone please help me with this one more question?
Lake
line vty 0 15
Cheers,
Fabio
That worked, but it does not like my password.
This is my command:
conf t
  username admin password password
I even did:
line vty 0 15
  password password
I don't know what is missing
Lake
