SSHv2 - RSA Keys
zekebashi
Level 8
Level 8
I created a simple config file, listed below, and tried to copy and paste this config on a 2960-8Port switch. After pasting this file,  I receive as error message when I issue this command "show ip ssh SSH Disabled - version 1.99 % Please create RSA Keys to enable SSH (of at least 768 bits size) to enable SSH v2. Authentication timeout: 120 secs; Authentication retries: 3"
I can't figure out why ssh v2 won't enable. I've tried it on several boxes/switches but I still receive the same error message.
Any idea as why this happens.
Thanks in advance.
Best, ~zK
no service pad
hostname Sales-SW-ACC2
ip domain name my.company.come
boot-start-marker
boot-end-marker
enable secret 5 xoadou435o4nadgaet!%Aou2
no aaa-new-model
ip dhcp pool 10.0.0.0
    network 10.0.0.0 255.255.255.0
    lease 0 0 10
service dhcp
spanning-tree mode past
spanning-tree pordtfast default
vlan internal allocation policy ascending
crypto key generate rsa generate-keys modulus 1024
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface vlan1
ip address 10.0.0.1 255.255.255.0
ip sea enabled reaction-alerts
ip dhcp excluded-address 10.0.0.1 10.0.0.10
line console 0
line vey 0 4
   privilege level 15
transport input telnet
line vty 5 15
no login
end
Philip D'Ath
Meraki Community All-Star
17 Replies 17
Philip D'Ath
crypto key generate rsa generate-keys modulus 4096
Thanks, Philip!
I've not tried your recommended solution yet and I was wondering if you could clarify for me why selecting this modulus would work over the the one I used.
Much appreciated.
~zK
Philip D'Ath
It's not the modules you got wrong.  You config says you are creating "rss" keys, which is invalid.  You need to create "rsa" keys.
And if you are going to create keys why bother doing 1024 bits when you can do 4096.
That was a typo. It's "rsa" not "rss". Thanks for catching that! We're following a company standard for now by using the 1024; nonetheless; would the modulus size cause the config to produce that error?
Philip D'Ath
No, the modulus would not create that error.  The error suggest to me that the RSA keys did not in fact get created.  Does "show ip ssh" show that a RSA key exists?
when I issue this command "show ip ssh, I receive the following output:
"SSH Disabled - version 1.99 % Please create RSA Keys to enable SSH (of at least 768 bits size) to enable SSH v2. Authentication timeout: 120 secs; Authentication retries: 3"
Philip D'Ath
If you issue the command to create the RSA key again what does it say?
So, when executing this command "crypto key generate rsa generate-keys modulus 1024", this is the output I receive
"an error occured"\"\\\"error deploying config ssh does not seem to be enabled show ip ssh\\\r\\\\nSSH Disabled - verision 1.99\\\\r\\\\\n%Please create RSA keys to enable SSH (of at least 768 bits size) to enable SSH v2.\\\\r\\\\nAuthentication timeout: 120 secs; Authenticaiton retries: 3\\\\r\\\\Sales-SW-ACC2#\\\"\\n"an"
Philip D'Ath
Either you have using a limited "K8" image, or you have a buggy version of the software on that switch.  I would recommend you upgrade the switch software to a gold star release.
Thanks for your input. I'll verify that with Cisco.
Much appreciate.
Best, ~zK
I verified the IOS on the switch and it's a12.2 IPBaseK9 image.
If I have a config file of a similar switch containing the crypto pki trustpoint TP-self-signed-.... and crypto pki certificate chain TP-self-signed-.....  statements included in the config file listed below and then I pasted these statements onto the switch, would that cause the rsa key to get rejected?
I did a little research and found out that if I removed the rsa key by using this command " crypto key zeroize rsa" and then added the "crypto key generate rsa generate-keys modulus 1024, then that would work. Any thoughts?
no service pad
boot-start-marker
boot-end-marker
no aaa-new-model
    lease 0 0 10
service dhcp
interface vlan1
line console 0
line vey 0 4
   privilege level 15
line vty 5 15
no login
end
Thanks, ~zK
Philip D'Ath
You should definitely not copy across the existing trustpoints.  When you create the RSA key it will create its own new trustpoints.
12.2 is pretty old.  Can you upgrade it to a modern "gold star" release?
So, should I negate both cyrpto pki statements, add this command:  crypto key zeroize rsa, and then add crypto key generate rsa general-keys modulus 1024?
I will upgrade the IOS to the gold star, as well.
Much appreciated.
Best, ~zK
Philip D'Ath
Correct.
