Need to know why interface status shown Inactive state in nexus 5596
djagdale97
I have nexus 5596 switch in which interface state is shown inactive even if port is admin up. i want to know why port status is shown as inactive. below is the port configuration.
show run interface Eth1/30
!Command: show running-config interface Ethernet1/30
!Time: Fri Dec 20 08:35:12 2019
version 7.0(5)N1(1)
inherit port-profile XYZ
spanning-tree bpduguard enable
below is the port profile config
show running-config port-profile XYZ
!Command: show running-config port-profile XYZ
!Time: Fri Dec 20 08:36:36 2019
version 7.0(5)N1(1)
port-profile type ethernet XYZ
switchport trunk native vlan 7
spanning-tree port type edge trunk
switchport access vlan 7
switchport trunk allowed vlan 7
no lldp transmit
spanning-tree bpdufilter disable
state enabled
below is the interface status
show interface Eth1/30
Ethernet1/30 is down (inactive)
Dedicated Interface
Thanks in advance..
Dhiraj Jagdale
balaji.bandi
we need to look a couple of outputs before we can come to a conclusion what is wrong?
1. do you have vlan 7 in the VLAN Database : issue show vlan to see that vlan exists or not.
2. what is the device connected behind this port ? any Server with Actve/Standby ?
3. can you post "show run interface Eth1/30 expand-port-profile"
4. what is the outcome if you do not attach the port-profile.
Another side note, any there any other ports also using same port-profile and working? if so please post that interface to examine.
once the port working "should work as expected" with port-pfoile then we can look and tweak the config of port-profile.
BB
i faced same issue and issue resolved
i missed this, Directly created a vlan without database===> ( do you have vlan 7 in the VLAN Database : issue show vlan to see that vlan exists or not)
Hi. I have 2 core switches which are logically made into one switch via svl links between each other. There is a port channel to an access switch with two uplinks, one from core switch 1 and one from backup core switch. (Port 1/2/0/5 to ten1/1/1 and port 2/2/0/5 to ten 1/1/2). To check the backup on access switch I shutdown port 1/1/1 and now the connection is lost. If i want to verify if the backup link from 2nd core switch is working, can I shutdown the interface from primary core switch as well to see if the access switch receives traffic from port 1/1/2?
marce1000
 - Below you will find a number of possible causes : actually as a test physical disconnect the port for a moment and re-connect  , then issue show logging ; you may  get additional info.
             https://packetpushers.net/cisco-nexus-port-inactive-status/
M.
