SSL v2 and v3 - Catalyst 3560
tladd0001
A vulnerability scan shows that SSL version 2 and 3 protocols have been detected on a couple of my Cisco Catalyst 3560 switches.  What command should I use to disable these?
Tom
Collin Clark
Tom-
To disable the web server on the switch, from config mode enter-
no ip http server
Just hat I needed - thanks for your help!
Tom
