Stack 2960s not full
Juan Ibañez
Level 3
Level 3
I have 4 switchs 2960s in stack, but this not full ring.
SW_ACC_P5N_CAMO#sho switch detail
Switch/Stack Mac Address : 64a0.e7d5.1580
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 64a0.e7d5.1580     15     1       Ready
2       Member 2c3f.3808.2600     14     1       Ready
3       Member 68bc.0cac.f180     5      1       Ready
4       Member 04da.d296.5780     1      1       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1       Down        Ok              None       3
  2        Ok         Ok                3        4
  3        Ok         Ok                1        2
  4        Ok        Down               2      None
the interface stack 1 for switch 1 is down and interface stack 2 for switch 4 is down.
I do  insert this command "switch 1 stack port 1 enabled" but interface are not up.
Reza Sharifi
Check the physical cables.  They maybe loose or disconnected.
The physical cables are new, and all interfaces are connected.
so the stack is formed
