LAN trunk issue
weichenb2
Community Member
            I have two 2950 LAN switches (dinosaurs) that am trying to connect via a trunk (Fa0/24 to Fa0/24). The configuration on both sides is as follows.
interface FastEthernet0/24
description Trunk to Madison-Ultra-2950-3, Fa0/24
switchport trunk allowed vlan 1,128,1002-1005
switchport mode trunk
description Trunk to Madison-Ultra-2950-4, Fa0/24
The interfaces on both sides come up/up but I never see the trunk come up and CDP info is nver share (even though configured globally and on interfaces). Also, I am unable to ping the GW (10.15.28.1) from switch 4. Finally, the interface Fa0/24 on switch 4 is taking excessive errors, even when I move the tunk to another port on switch 4 and replace cables. So, the errors cannot be attributed to the cable or the port. The errors seem to follow the link to the other switch.
6 Replies 6
mfurnival
Level 10
Level 10
Can you post the config from both switches please?
What happens if you remove the trunking configuration from both ports - do they see each other via CDP and do the errors stop?
I hadn't thought about the cross-over cable. I will try one.
Madison-Ultra-2950-3#sh run int fa 0/24
Building configuration...
Current configuration : 160 bytes
description Trunk link to Madison-Ultra-2950-4, Fa0/24
Madison-Ultra-2950-4#sh run int fa0/24
Current configuration:
description Trunk to Madison-Ultra-2950-3, Gi0/2
Madison-Ultra-2950-3#sh int status | i 0/24
Fa0/24    Trunk link to Madi connected    trunk      a-full  a-100 10/100BaseTX
Madison-Ultra-2950-4#sh int status | i 0/24
% Invalid input detected at '^' marker.
Madison-Ultra-2950-3#sh int fa 0/24
FastEthernet0/24 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000f.2456.b6d8 (bia 000f.2456.b6d8)
  Description: Trunk link to Madison-Ultra-2950-4, Fa0/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 100BaseTX
  input flow-control is unsupported output flow-control is unsupported
  Last input 00:53:42, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:04:41
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4000 bits/sec, 3 packets/sec
     800 packets input, 171540 bytes, 0 no buffer
     Received 800 broadcasts (0 multicast)
     0 watchdog, 800 multicast, 0 pause input
     517 packets output, 54306 bytes, 0 underruns
Madison-Ultra-2950-4#sh int fa0/24
  Hardware is Fast Ethernet, address is 0005.325d.d158 (bia 0005.325d.d158)
  Description: Trunk to Madison-Ultra-2950-3, Gi0/2
     reliability 143/255, txload 1/255, rxload 1/255
  Keepalive not set
  Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
  Last input never, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:10:42
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  5 minute output rate 3000 bits/sec, 3 packets/sec
     0 packets input, 792923 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     7806 input errors, 7806 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast
     13875 packets output, 1764946 bytes, 0 underruns
Madison-Ultra-2950-3#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/24      on           802.1q         trunking      1
Gi0/1       on           802.1q         trunking      1
Port      Vlans allowed on trunk
Fa0/24      1,128,1002-1005
Gi0/1       128
Port        Vlans allowed and active in management domain
Fa0/24      1,128
Gi0/1       128
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/24      1,128
Gi0/1       128
Madison-Ultra-2950-4#sh int trunk
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: N/A
Operational Speed: 100
Operational Duplex: full
Operational Auto-MDIX: N/A
Madison-Ultra-2950-3#sh ip igmp snooping vlan 128
Global IGMP Snooping configuration:
IGMP snooping              : Enabled
IGMPv3 snooping (minimal)  : Enabled
Report suppression         : Enabled
TCN solicit query          : Disabled
TCN flood query count      : 2
Last member query interval : 1000
Vlan 128:
Immediate leave                     : Disabled
Multicast router learning mode      : pim-dvmrp
Source only learning age timer      : 10
CGMP interoperability mode          : IGMP_ONLY
upsilon22222
Community Member
Since this is an older switch, have you verified that you are using a crossover cable and not a regular cable? I believe the older switches do not support the auto-sensing feature.
Otherwise, perhaps you could provide some output from the following commands:
sh run int fa 0/24 (on both switches)
sh int fa 0/24 switchport (on both switches)
  Keepalive not set
Gi0/1       128
Fa0/24      1,128
Gi0/1       128
Fa0/24      1,128
Gi0/1       128
Vlan 128:
Please post the commands:
sh int fa 0/24 switchport  (for both switches)
This command will show us the encapsulation and/or if there is a trunk negotiation occurring.
EDIT: Nevermind, I see you posted the trunk command alternative and I see you are using dot1q and the status is in "trunking mode".  Please let us know if your cable is correct.
  Are you sure you are connecting to the correct ports or are your descriptions just incorrect?  Switch 4 says it goes to G0/2  not 0/24 .   Also I don't understand why you can't do a show int trunk  or show interface status , are you sure they are both 2950's . Please post a show version from both switches.  Set both connecting ports to switchport mode access , this will make both an access port in vlan 1 and you should see cdp after this.  Once your ports are verified then you can put your trunk parameters back in and see what happens. Also make sure all your layer 2 vlans are created on both switches, verify with a show vlan .  I believe the gig ports on these is gig only so you cannot connect the gig ports to a fast ether port and have it work.
